Steam port kit issue
Motion Raceworks V2 LS Flex Line Coolant Crossover Steam Kit for Low Pro Plastic Intakes 10-10006
hey guys I ordered this steam kit because I’m running a tbss intake and the mounting bracket looks as if I have to pull two of the head bolts to mount if does that sound right, also they only sent me one 90° elbow and 1 45° degree elbow I would have though they would send 4 90° an fittings to tie in all four corners of the head
I'm not sure why you bought that kit when it's made for an aftermarket low profile intake like a LS3 or Fast, Not a tall intake like the truck intake.... It does say "This kit will work with stock LS intakes (not a truck intake)"
They show how it's plumbed on their web page and it shows only one 90 and one 40. The mounting bracket doesn't use head bolts it most likely uses two of the fuel rail or intake bolts.
I'm not sure why you bought that kit when it's made for an aftermarket low profile intake like a Fast, It does say "This kit will work with stock LS intakes (not a truck intake)"
They show how it's plumbed on their web page and it shows only one 90 and one 40. The mounting bracket doesn't use head bolts it most likely uses two of the intake bolts.
