Generation V Internal Engine 2013-20xx LT1
Max lift with stock springs?
Old Feb 1, 2023 | 09:59 AM
73metalman's Avatar
Default Max lift with stock springs?
Google didn't help much, nor a popular FB page. I'm trying to spec a cam that will give me a bump in hp/Torque but keep the stock fuel lobe and valve springs. Low end torque and MPG is more of a concern. Will probably need multiple engines as I will be using this in a truck to put on a lot of miles so don't want to dump much into every engine.
Old Feb 1, 2023 | 10:54 AM
TurboBuick6's Avatar
Stock springs are pretty close to max lift. Bind on a stock spring should be roughly 1.280".
Old Feb 1, 2023 | 11:17 AM
ddnspider's Avatar
Buy a $50 set of LS6 springs.
Old Feb 1, 2023 | 01:48 PM
Installed heights are different.
Old Feb 1, 2023 | 02:01 PM
ddnspider's Avatar
I guess a million buyers with LS6 springs running all sorts of cams are all about to explode. There's a reason companies like Summit Racing spec their cams as working with LS6 springs.
Old Feb 1, 2023 | 11:15 PM
73metalman's Avatar
Default For a Gen v?
Are the springs the same for a gen V? And the point was to not have to take the effort to change the springs.
Old Feb 1, 2023 | 11:30 PM
73metalman's Avatar
Default Found the answer
Stumbled on LSxelerations website which has what I assume are factory springs and says max lift is .555. Stock L86/LT1 lift is .551 on the intake. I'll just have to plan for new springs and buy the tool.
Old Feb 2, 2023 | 09:51 AM
If i had to guess, they offer an offset lock or retainer to get the height to 1.800". If you take an LS6 spring with a 386 rate and install at 1.88, you would only have 60lbs on the seat.
Old Feb 2, 2023 | 09:59 AM
ddnspider's Avatar
You are correct, I think it can be done, but to be fair I didn't realize I was in the Gen V section. My fault!
