Generation V Internal Engine 2013-20xx LT1
Front timing sensor issue
Old Mar 9, 2024 | 10:34 PM
EdThompson's Avatar
Default Front timing sensor issue
I had a 408 built and opted to use a gear drive for the cam. I now am running into problems with the timing sensor, it's bottoming out on the timing gear and leaving approximately 1/4" out of the cover. Is there a different sensor I can use, or is there a different timing cover I can use to remedy this? Do I have to have a spacer made to cure this? Thanks for any help.
Old Mar 10, 2024 | 10:15 AM
Which engine/vehicle? Gen III or IV?
Old Mar 10, 2024 | 03:13 PM
EdThompson's Avatar
Gen 4 6.0 truck block with 823 heads.
Old Mar 10, 2024 | 03:46 PM
No wonder I got confused. This is the Gen V forum, not Gen IV.
