650 bhp from a stock bottom end L86/LT1?
Basically the title. Im aiming for 650 bhp from a stock bottom end LT1 with the factory (but ported) heads, a cam, LT2 intake, and and a set of long tubes. Also running 91 AKI (95 RON) pump gas, more compression is out of the question. Is it possible?
Any recommendations for a cam? Currently looking at the BTR 230 cam.
BTR 230 Cam Specs: 230/24X (why does BTR hide the duration?), 112 LSA, 644/644. This thing apparently made 680 hp with a set of GMPP Heads and an MSD intake
Also thoughts on port injection with an LT1?
thx in advance <33
thx in advance <33
Apparently getting ideas and asking people with knowledge what works and what doesnt work is bad. My bad for not being born already knowing all this.
To address your second question
If you actually read my posts, you'd realize every single one asks a completely different question. No need to reply like an *******. Either share your knowledge or dont reply.
Also its wasting, not waisting.
You don't need port injection for NA build. The LT4 fuel system will support a NA build up to around 700whp on E85. If you go with the 230 cam I would go with a different manifold. The BTR 225 and LT2 manifold would pair well. Hit up places like Pray Performance and GPI and ask their recommendations on NA combinations. It's not hard to get to 600whp through a A8/A10 with a SBE LT1 and a sub <230 duration cam.
Ty <33
