Aussie Ford Falcon
Ford (Aust) uses a 4 litre (244cuin) straight 6 and a 5.4 litre ( 329cuin) V8 in many different guises.
The 6 can be had as
a) 190kW (255hp), 383Nm (282ftlbs)
b) 245kw (328hp), 480Nm (354ftlbs) Turbo
c) 270kw (362hp), 550Nm (405ftlbs) F6 Typhoon (Turbo)
The V8 can be had as
d) 230kW (308hp), 500Nm (368ftlbs)
e) 260kW (348hp), Quadcam
f) 290kW (389hp), 520Nm (383ftlbs) Quadcam
http://www.ford.com.au/servlet/Conte...agename=DFY/AU
http://www.fpv.com.au/index.aspx
Oh, and one other thing. Why do ALL Ford V8's sound so much better than GM's small or big blocks ?
When I was down in Oz I decided in my brief time one simple thing about Aussies and cars: They will try anything.
Turbo falcon is a fun ride, once you get over the fact you are on the
wrong side of the road.
Didn't GM just change the firing order on their V8 engines to that of the Ford Windsor because of some kind of horse power advantage ? Also GM is moving the distributor to the front of the NASCAR engines, like the Fords !
The 6 can be had as
Produced in Ford's Windsor plant in Canada, the Barra 230 V8 boasts VCT variable camshaft timing on each camshaft per bank as well as three valves per cylinder, electronic throttle control, failsafe cooling system and unique, Australian-designed inlet and exhaust manifolds.
Reddington said the extra power and torque were by-products of employing additional hardware to improve the knock sensing capability.
"The engine was designed to power the new range of F-Series trucks in the US and always delivered good low-down torque.
"The addition of two knock sensors allows for a more aggressive ignition calibration with the variable camshaft timing and a greater degree of spark advance.
For those who dont know FPV or HSV are the Australian performance branches for Australia Ford and GM like SVT is to USA Ford or AMG is to Benz etc.
