1st Gen Camaro
I bought a 1967 RS Camaro back in Feb '10 and it turned out to me more work than I was capable of doing. So I sold it as a project car and bought another one in Nov. '10 and have been working on it ever since. Here's a link to my build thread: http://www.camaros.net/forums/showthread.php?t=173910 The first two pages are the first car, the new car start on page 3.
This is a pic of how it sits today:
-SpeedTech Upper & Lower Control Arms
-Hotchkis 2" drop coils
-Hotchkis front sway bar
-Bilstein Shocks
-Delphi 670 steering box
-Wilwood Dynapro front disc brakes
-Fesler solid aluminum body mounts
This fall it will be having some work done on the rear frame rails, and at that time they will replace the 10 bolt with a 12 bolt posi that I'm putting together right now, disc brakes, subframe connectors, rear suspension, etc:
-12 Bolt Posi 3:31's
-Hotchkis 1 1/2" drop leafs
-Hotchkis subframe connectors
-Wilwood Dynapro rear disc brakes
And here's why I'm here:
It has a late 80's/early 90's 350 sbc. It was rebuilt when I got it. I don't know the specs, it's got some get up and go, but it's fairly mild. I want to upgrade the engine and transmission (has a 4 spd saginaw in it now) next spring. Originally I was thinking about a 383 stroker, but now I'm leaning towards an LS motor and I'm here to learn everything I can before I make my decision. Any and all help is appreciated!
My options are:
1) LS carbed
2) 383 stroker (GM ZZ383)
3) Big block (396, 427, 454, etc.)
The 383 would drop right in with no mods, so I could spend more money on a better motor. The big block would be a fairly easy swap as well. The LS would require new oil pan, motor mounts, ignition box, etc (and I'm not sure what etc. is yet).
The LS is completely foreign to me, so I'm trying to learn as much as possible, but I love the idea of an easy 500hp streetable motor.
