how many gears does an automatic WS6 have?
Old Dec 6, 2006 | 01:49 PM
bostonredsox_ws6's Avatar
Talking how many gears does an automatic WS6 have?
What is the horsepower on a 2001 Ram Air? 325 or 350? Also how many gears does an automatic WS6 have? What should an auto WS6 run 1/4. How can I make the an Automatic pull like a Manual Transmission
Old Dec 6, 2006 | 01:55 PM
JT LS1's Avatar
Old Dec 6, 2006 | 01:58 PM
NoGamesLS1's Avatar
4 gears Its a 4l60e trans. They were rated at 325 hp. If its completelty stock it should run mid-high 13 seconds. I seems like you are new to this so the first mods I would suggest to you would be an intake lid and a programer. The programer is pretty much useless for a 6 speed trans, but for your auto you will really notice a difference because it will change your shift points and the shift firmness
Old Dec 6, 2006 | 02:06 PM
jpat1023's Avatar
First of all, this should have been posted in 'Newbie Tech', but its cool, now you know.
You should put down anywhere from 290-315 rwhp(rear-wheel hp, different than crank hp)
If you are completely stock, you should run mid to high 13's at the track.
Don't worry about 'makin your auto pull like a manual trans.' In no time at all, manuals will be a thing of the past for you. Well, that is as soon as you put in a 3000-3500 stall, a shift kit, and a trans cooler.
edit: don't waste your money on a handheld programmer. If you want to tune something, save your money and get efilive or hptuners.
btw, you will probably want to spend a lot of time on this site before you make any kind of purchases. Good Luck.
Old Dec 6, 2006 | 02:12 PM
tacklebox's Avatar
It depends on the car/driver really, my ex-girlfriend dad had an 01 TA auto that ran 13.3 bone stock his first time to the track in it.
Old Dec 6, 2006 | 02:30 PM
2000LS1TA's Avatar
A4 = 4 gears
Old Dec 6, 2006 | 06:44 PM
MjMaro's Avatar
What the
Old Dec 6, 2006 | 06:56 PM
slick1851's Avatar
I would highly advise driving with the traction control on, these cars are very powerful.......
Get a Shift Kit" and a Trans cooler, and a 2,800 stall or so........Please ask alot of qeustions on this site and dont do anything without researching 1st
Old Dec 6, 2006 | 07:02 PM
02 Camaro SS's Avatar
Yea, seriously spend a LOT of time on this site before you spend a dime. It will be the best mod you do, hands down. Ask anything and everything you want because there will be several people on this site who know the answers and you can find volumes of invaluable information using the search. One of the best pieces of advice is to figure out your longterm goal for the car and plan your mods accordingly.
Old Dec 6, 2006 | 08:01 PM
02NHRAtransAm's Avatar
Old Dec 6, 2006 | 09:16 PM
SCRWS6
Guest
Posts: n/a
Amen to the Researching!!!!!!!!!! I spent more money on crap before I finally found this site........ LS1tech rules!!!!!!!!!
welcome too!!!!
Old Dec 9, 2006 | 12:17 PM
2000SLPZ28's Avatar
ill tell you the best mod for you to get first. take the A4, and the ten bolt and chuck it in a scrap yard, thats all there good for. other then that i hope you like your new car.
Old Dec 9, 2006 | 12:45 PM
RollinSScamaro's Avatar
Naw.. don't thro wout the A4 and 10 bolt.. some people have luck with them and others dont.. mine didn't give out till i had head and cam on my car... just put on good tranny coolers and a shift kit.. heat is the biggest problem that i found for mine.. i never broke any parts pulling 1.6 60 ft times.. and that was on a stock 10 bolt.. only thing i had problems with on that was the carrier bearings.. i also put 3.42 gears in also.. seemed like it was holding up well at the time.. but for how long.. ya never know? Good luck!
Old Dec 9, 2006 | 12:47 PM
CaMaRo67RS355's Avatar
strip shift kit, good 3,000 + stall, trans cooler, itd be a good idea to get a new trans mount as well... changing the rear end gear will also help you get more pull if thats what your wanting. http://www.ws6project.com/user_stor/...34643f7a1f087e
