Another relative newbie... '04 GTO
Newbie here - wandered over to start looking into engine/tuning info. Actually have been lurking a while, and realized I didn't have an intro post.
My car links are in my sig below (or should be).
My DD is my 2004 Pontiac GTO, now in the process of being converted to a Holden VY/VZ Monaro mutt.
As for my current mods, here's a list:
Engine:
* K&N AirCharger intake & baffle (IAT sensor placed in filter)
* Hand ported/polished throttle-body w/ coolant bypass
* NGK TR55IX Iridium Spark Plugs (gap to 0.055 inch)
* Taylor "409" 10.4mm wires
* EFILive street tune in progress
Transmission:
* B&M Ripper short-shifter kit
* Speed Inc's CAGS eliminator
* Royal Purple Synchromax (transmission fluid)
Exhaust:
* DynaTech long-tube headers w/ cats
* SLP Power-Flo stainless cat-back
Suspension/Brakes/Wheels:
* Pedders front "radius rod" bushings
* Delco Durastop front pads (Corvette C5 size)
* Front PowerSlot rotors w/ painted calipers
* (summer) Voxx MG 17x8 wheels / 245/45/R17 BFGoodrich g-Force T/A KDWS (needing replacement now)
* (winter) Stock 17x8 wheels / 225/50/17 Bridgestone Blizzak WS-50
Body:
* 2005 Monaro VZ front bumper and side markers
* Gravana Tuning Type W ("Woodward") hood
* Monaro/Commodore SS molded splash guards (painted Silver)
* Deleted spoiler, filled/painted stock holes
* Replaced Pontiac badging with Holden emblems front, rear and dash
Interior/Electronics:
* Installed homemade dead pedal
* Hard-wired Valentine One radar detector w/ mount next to interior rear-view mirror
Pending install:
* Hotchkis front/rear swaybars (now in a box in my garage)
* 2005 OEM calipers (320mm vs 296 mm diameter rotors)
* ATE Super Blue Racing (brake fluid)
* port/polish LS1 heads (OEM 241 casting)
Engine:
Transmission:
Exhaust:
Body:
Pending install:
And if anyone cares, here are some pics...
![](https://static.flickr.com/132/318906540_3ac40572bb.jpg)
![](https://static.flickr.com/138/318906429_711d8a63bb.jpg)
![](https://static.flickr.com/123/318906850_458b6412f1.jpg)
![](https://static.flickr.com/133/318906781_2a16ad8c62.jpg)
![](https://static.flickr.com/123/318906596_758b379c50.jpg)
As a sidebar, I also got picked as an AutoBlog Reader Ride of the Day...
Some updates:
On the appearance front, I added some more exterior badging to complete the swap - and maybe to be less confusing to others - as well as swapped in a new set of 18's w/ OEM 235/40/18 Potenza's for summer rubber:
![](http://farm1.static.flickr.com/242/445498645_788abaa205.jpg)
![](http://farm1.static.flickr.com/243/445494458_e24de0fa25.jpg)
![](http://farm1.static.flickr.com/180/445498465_5635c07774.jpg)
On the performance front, I also wanted to do some more to the GTO/Monaro for handling, as I hope to autocross some more.
As the car wallowed some on the course, (and I'm already stuck in STU) I wanted to see how new swaybars changed things, so in went a new Hotchkis set.
First were the rear bars (they were easier).
Here's a shot vs. stock:
![](http://farm1.static.flickr.com/230/497377150_9e3f3d29eb.jpg)
I had to drop the rear diff to get at the swaybar mounting bolts on the subframe. I wound up replacing the rear diff mounting bolts today (yay to torque-to-yield
), so now I don't have to be as paranoid and take it so easy on launches anymore.
Here's the bar in place:
![](http://farm1.static.flickr.com/207/497414069_e2ff44a29e.jpg)
I'll have to play with the settings (there are four spots on the bar) to see where I like them best.
As for the fronts, I had to drop the front cradle to get it out - which was the bigger pain in the a$$.
Here's another "vs. stock" shot:
![](http://farm1.static.flickr.com/223/515497892_b06fb619d6.jpg)
As well as my new Aussie end-links:
![](http://farm1.static.flickr.com/221/515523895_31e232248a.jpg)
![](http://farm1.static.flickr.com/230/515524041_6bab340a01.jpg)
Here's the bar in place - I also had to undo the trans fluid cooler lines, so it was messy, too.
![](http://farm1.static.flickr.com/210/515498074_a1a2e5cf6b.jpg)
And finally, the new end-link in place:
![](http://farm1.static.flickr.com/194/515524111_b93215e785.jpg)
I have it in the stiffest setting, and will see how things go from here.
All in all, I'm pretty happy so far; now I'll have to see where I like the bars to be set.
![](http://farm1.static.flickr.com/183/445494816_adfb9192ca.jpg)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
