Broken Starter Mount
Old May 18, 2005 | 12:27 AM
Ed Blown Vert's Avatar
Default Broken Starter Mount
Went to start the car tonight. Heard a snap.
One tab on the starter broke. The other bolt snapped off the tab on the block. How would I fix the tab on the block??
Old May 18, 2005 | 01:35 AM
WILWAXU's Avatar
Dooh!
Starter is easy.. block not so easy.
I've seen those "fixed" before, but most have replaced the blocks.
First question is why it broke. You had a leaking head gasket lately?
Old May 18, 2005 | 08:30 AM
I have no idea why it broke, I was checking for a coolant leak. Went to start it to move it back into the garage.
No leaky head gasket. The thermostat housing was the culprit. Course one of those bolts broke off in the water pump.
Old May 18, 2005 | 09:03 AM
LS69TA's Avatar
I've fixed one on a older 350 block with a stud kit thingy, but this doesn't look good for ya bro.
Old May 18, 2005 | 10:05 AM
I eventually wanted another block, but not so soon and not for this reason.
Old May 18, 2005 | 10:11 AM
Oscar Will's Avatar
I haven't seen anyone fix one of these easily. This could be terminal. It might be possible to weld up and repair but I would think the job would need to be done on an engine stand. Good luck.
Old May 18, 2005 | 10:12 AM
Grimes's Avatar
I'd just get someone who knew how to weld aluminum to weld the tab back on. it's a stressed point, but not "critical"
Old May 18, 2005 | 10:26 AM
I'll check into welding it. I hope I can keep the engine in the car.
