can't reach yank's website
Sounds like you might have a Domain Name resolution issue.
If you drop to a command prompt
(go Start... Run... and type COMMAND in the box that appears)
type in
nslookup www.converter.cc
the 'non-authoritative answer' should be
216.105.206.189
Try this link:
http://216.105.206.189
type in
216.105.206.189
Try this link:
7 Second Club
still wont show
it says
DNS request time out.
timeout was 2 seconds
***cant find server name for address 10.1.1.241: Timed out
*** Default servers are not available
Server: Unknown
Address: 10.1.1.241
non-authoritative answer:
Adress: 64.74.223.197
i wonder whats wrong?
it says
Server: Unknown
Address: 10.1.1.241
This thread over on SSU had a similar symptom:
http://www.seatstaysup.com/forums/sh...&highlight=DNS
Not sure where things are going amiss.... Sorry!
Adkoonerstrator
Try this
Goto this folder/file
C:\WINDOWS\System32\drivers\etc\hosts
Open the "hosts" file with notepad and edit it with this line. Just put this line down at the bottom of the page.
216.105.206.189 www.converter.cc
After editing the file, save the changes. Then completely exit out of your browser(File-->Exit) and open it back up.
Type in www.converter.cc and it should open up the right page.
By putting that line above in the hosts file it basically tells the browser what address to go to when you type in yanks site.
Also, while your in the hosts file check to make sure www.converter.cc is not already listed in there somewhere. If it is just delete the line it is on.
