Nitrous
My MAF sensor went bad so I replaced it with a new one. I decided to test the freezing of the wires on my broken one. The one wire was slightly bent, which is why it went bad. Either way, it would make no difference in the experiment. I didn't have N2O available but I did have a Heliox mixture that my boss said I could fool with. (Hospital) It's not so much the chemical anyways, more the temperature I'm working with. I sprayed Heliox through the MAF sensor and sure enough the wires froze and shattered off, and they literally shattered like glass. Is the 3800 MAF sensor a different design or something?
If any of you want good N2O info, and are clubgp members, talk to Tweaky. He's the nicest guy, he's been spraying cars since I was in diapers, and he will help you with anything you need to know about the juice.
