Track Prep list
Old Apr 28, 2009 | 03:25 PM
Panther427's Avatar
Default Track Prep list
So i thought id start a thread with everyones idea for getting best times at the track. Lucky for us GXP owners are cars have a air compressor. This makes adjusting tire preasure easy.
Air front tire presure down. Air rear tires up to max.
Remove driver side head lamp. i have seen people use belt dressing on the tires like VHT track bite. I like to turn traction control and stabilitrack off.
Spin off the tires to clean them off make them warm up a bit.
Try to get up to the line first Stall out the T/Q converter, then select the RPM i wanna launch from.
Old Apr 28, 2009 | 06:38 PM
CenTexSS's Avatar
I have a bottle of that track bite, I wouldn't use it on the tires you drive on everyday.
Old Apr 29, 2009 | 08:33 AM
beznich's Avatar
Panther can you help me out with this?
"Try to get up to the line first Stall out the T/Q converter, then select the RPM i wanna launch from."
What do you mean by stall out the T/Q? I've heard of torque converter stall, and understand the basics, but I guess I'm confused.
Old Apr 29, 2009 | 08:38 AM
CenTexSS's Avatar
Hold the brake, and rev up the motor then launch.
Old Apr 29, 2009 | 08:46 AM
beznich's Avatar
OK, I thought there was more to it thatn that, hahahahahahhaha
That's what I get for thinking - there will be no more of that.
Old Apr 29, 2009 | 10:36 AM
radorider03's Avatar
Thats what you gotta do to get that 60' down
Old Apr 29, 2009 | 11:24 AM
Panther427's Avatar
YA that basically it, i have herd some people call it flashing the T/Q.
It help the car to not have any lag in the launch.
Old Apr 29, 2009 | 11:58 AM
beznich's Avatar
Oh I hold the brake down and launch around 2K or so, but I still just light the tires. If I ease in to it, no tire slip but still the same 60' times. I'm leaning towards the tires which is why I am going to look for something stickier. No to mention burning the 20's will get expensive.
Old Apr 29, 2009 | 12:12 PM
Panther427's Avatar
lol 18's cost enough, glad i dont have 20's. I like to stall out to 3k rpm, then inch forward for the lights and then launch around 2K aswell.
Old Apr 29, 2009 | 12:21 PM
DP 08 GXP's Avatar
i dont believe i do unless i just dont know about it. where is it located?
Old Apr 29, 2009 | 12:24 PM
Panther427's Avatar
Well we dont have a spare tire. So we got a tire inflator and can of tire sealant instead. Look where the spare tire would be.
Old Apr 30, 2009 | 02:37 AM
StealthV8's Avatar
Take as much weight off your rear tires as u can.. Because we are fwd, when we first take off, the weight transfers to the rear and takes the weight away from the front.
By Brett Foote | 2026-06-04 05:00:17
