Electric Cutout
Old May 18, 2009 | 10:51 AM
06ImpalaSS's Avatar
Default Electric Cutout
Was wondering if anyone has put any electric cutouts on their imp. Ive been looking around trying to see whats out there. My only concern is that I'll be disappointed if it kicks into DoD and I hear it in 4 cylinder mode.
Old May 18, 2009 | 11:08 AM
DP 08 GXP's Avatar
i have one the QTP on my GXP and i love it. i would think it would sound the same on the imp. when it goes into DOD it kinda sounds like a helicopter (best way to explain it). i love everything about mine.
Old May 18, 2009 | 11:23 AM
Panther427's Avatar
LOL that what i thought. Sounds alot like a helicopter. Other times it can almost sound like a subaru boxer motor.
Old May 18, 2009 | 11:49 AM
06ImpalaSS's Avatar
Where did you put yours DP? I was lookin under the car and i saw a spot by the right rear tire. I know people put them after the headers, but I don't know if that would throw a code or not.
Old May 18, 2009 | 12:17 PM
1 CLEAN SUP3R SPORT's Avatar
Is there a part # for the cutout???
Old May 18, 2009 | 12:57 PM
DP 08 GXP's Avatar
i got mine right after the res. some people have mentioned it will melt the gas tank since it is plastic but there is a heat shield (at least on the GXP) right in front of the tank and i also put up a heat screen like this on the gas tank. i also dont run it open constantly either.
http://cgi.ebay.com/ebaymotors/DEI-0...lenotsupported
here is where i got my cutout from
http://www.pfyc.com/pc/GN5002/04EXH/...nd+models.html
Old May 18, 2009 | 01:48 PM
06ImpalaSS's Avatar
On the second link I saw that you can get a 2.25 pipe and with a 2.5 valve. Wonder if that works with any pipe and any valve. If so I could buy the pipe from somewhere and the valve from DHM. Ive been reading alot that QTP is iffy and DHM is the way to go. Plus the warranty.
Old May 18, 2009 | 05:14 PM
lovemyls4's Avatar
I just bought a DMH and i will be cutting the res out and putting that in its place. Make sure you order the flowtech wye with it.
Old May 18, 2009 | 06:00 PM
06ImpalaSS's Avatar
WYE? So did you go to their site and order it? What exactly did you order so I know?
Old May 18, 2009 | 08:56 PM
so the size is 2.25 and 2.5???
Old May 19, 2009 | 07:47 PM
lovemyls4's Avatar
order 2.5 inch from dmh. All depends on where you place the cutout if you need it built into the wye or not.
Old May 19, 2009 | 08:01 PM
06ImpalaSS's Avatar
and you got the wye from DMH as well?
Old May 20, 2009 | 06:18 PM
since are cars are all based off the electronic,by addin the cutout will throw a code???
Old May 20, 2009 | 06:22 PM
06ImpalaSS's Avatar
Depends on where you put it. If you put it before the cat it will throw a code. If you put it after the last o2 sensor you should be good. Alot of people seem to be putting the cutout in place of their res. Personally I dont like the sound that raspy kickback sound you get when you get off WOT with the res gone. I think Im putting mine behind the res, but that could change.
For anyone looking for an electric cutout, you can go through DMH. I contacted them and they said they have the 2.25 Flowtech Y pipe to fit their 2.5 valve.
Last edited by 06ImpalaSS; May 20, 2009 at 06:24 PM. Reason: Because editing rocks!!
Old May 20, 2009 | 06:39 PM
^^^ alright as long as there after the o2 sensors i should be fine...i know i saw a post w/an impala who had it by his gas tank....thanks
