Smooth Intake Bellow
Old Jun 5, 2009 | 01:40 PM
Mgpeagle's Avatar
Default Smooth Intake Bellow
Ok, I would like one of these instead of the accordian type that is stock. Is this the right size I would need?
http://www.siliconeintakes.com/produ...d1384a6a48c8ec
Thnaks in advance.
-Mike
Old Jun 5, 2009 | 01:46 PM
06MonteSS's Avatar
LS1Tech Sponsor
no... need a 3.25" -- same one I have...
that 3.5" you linked to, is too big.. I found out the hard way... hah! as a matter of fact, I still have it sitting under my desk... never got around to sending it back... heh...
get some new t-bolt clamps too when ya order the stuff... much better than the stock clamps..
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jun 5, 2009 | 02:03 PM
Mgpeagle's Avatar
Excellent! Thanks Lou.
-Mike
Old Jun 5, 2009 | 02:28 PM
06MonteSS's Avatar
LS1Tech Sponsor
np man... you're welcome...
__________________
Old Jun 5, 2009 | 03:10 PM
Mgpeagle's Avatar
Well, that's on it's way.
Lou,
What size grommet did you use? And how'd you seal it? Did it fit in there good? Thanks again.
-Mike
Old Jun 5, 2009 | 03:19 PM
neilownz's Avatar
You can take the one out of the stock tube and drill a hole that size in the new elbow.
Old Jun 5, 2009 | 03:27 PM
06MonteSS's Avatar
LS1Tech Sponsor
no ya can't... if it's like ours is on our montes, there's no "grommet" in our stock tubes... the fitting is molded as part of the tube...
Mgp - check out the instructions for the K&N intake - http://www.knfilters.com/instructions/63-3059_inst.pdf I used the same size grommet as they have in theirs... 3/8" inner diameter I think it is... and I drilled the hole for it to be the same size as it's inner diameter...
then, I used some black rtv gasket/seal maker to seal it all up around it - on the inside and the outside...
__________________
Old Jun 5, 2009 | 03:30 PM
Mgpeagle's Avatar
Cool, good to know. Did you guys notice any difference? I'd rather have the air smooth until it hits the Throttle Body Spacer. I hate the accordian looking ones.
-Mike
Old Jun 5, 2009 | 03:36 PM
neilownz's Avatar
Ahh I assumed that was in the stock one already oops. I have the K&N kit.
Old Jul 30, 2009 | 12:07 AM
DirtyVegas23's Avatar
So, if I were to buy the HSRK and relocate the IAT into the filter somewhere, would I not need to drill any holes into this elbow?
Old Jul 30, 2009 | 07:38 AM
06MonteSS's Avatar
LS1Tech Sponsor
yes, you still have to drill the hole, because that fitting in the intake hose is for the crankcase vent breather tube... has nothing to do with the IAT sensor...
__________________
Old Jul 30, 2009 | 06:41 PM
92_Corvette's Avatar
anyone notice any gains from this. i was thinking about using a smooth elbow and a k&n filter instead of spending 250
Old Jul 30, 2009 | 07:38 PM
hexxLS4's Avatar
I believe the elbow on the K&N is what gives it that extra umph over the CAI using the stock elbow. I've owned both and you could feel a slight performance increase with the K&N....I attribute it to the elbow.
Old Jul 31, 2009 | 10:07 AM
RickAKATed10's Avatar
He's talking about just replacing the elbow and using a drop in K&N filter in the stock air box.
Old Aug 1, 2009 | 11:07 AM
06MonteSS's Avatar
LS1Tech Sponsor
yep, doesn't matter... still have to drill the hole/use the grommet and fitting in the new intake hose for that crankcase breather tube...
__________________
