is it possible to put a 6 speed transmission in this car
I got a responce back and it was for a v6 w-body... the manual 6 speed.
He said they want to make headers for the ls4 soon though if anyone wants to email milzy about that. I don't know if they would need a guinea pig or not.
Looks like someone is working on it. LSx series with the 6T75 (FWD/AWD 6 speed automatic from the Saturn Outlook/GMC Acadia/Buick Enclave).
http://www.fastfieros.com/projects/
The guy's post from fiero.nl:
We'll just have to wait and see...
Next is the 6T75 6 speed automatic mating to the LSx engines. All new bolt pattern, and I have to redesign the starter issue for this one too. PCS is 2 months out on beta with a contoller to run the 6 speed, but I have already talked with the lead engineer at GM for this transmission and he is helping me with the differences on the 6L80 vs the 6T75.. looking good for an OEM control solution.
Its been done to a 04 GTP
upgraded cartuning turbo kit
all larger charge pipes
tial 50mm
Getrag F40 6 speed
1200hp axels
1500hp triple disc clutch (tilton)
T72 ball bearing turbo
solid mounts
meth injection
black sabbath cam
130#springs
heads that flow better than stage 3-4 intense heads using stock valve (intense uses oversized)
new double roller (rollmaster)
ac delete
mls gaskets
head studs
custom 3" dp
3" cutout
boost a pump MSD
Mini AFC
79# injectors
tial 50mm
Getrag F40 6 speed
1200hp axels
solid mounts
meth injection
black sabbath cam
130#springs
ac delete
mls gaskets
head studs
custom 3" dp
3" cutout
boost a pump MSD
Mini AFC
79# injectors
That's exactly the kind of car I don't want to lose to, and the best thing about my built transmission is that even in D the transmission doesn't jerk me around before down shifting. The 4->3 and 3->2 both happen almost instantaneously.
#33
Agreed, and with the ecu, I figure the car knows a little better then me when
the best shift point is.
Would love to know if someone is actually going to do the swap,
a clutch in an ls4 fwd = one of my dreams
#34
I WANT A MANUAL SO BAD. It would improve the car by atleast 75%. I got mine tuned with HP tuners and the tranny still seems slow to react and sometimes doesn't downshift when it should. I feel like getting a GOAT, but the winter in Ontario is a B for RWD. A FWD manual V8 would be so nice to use all year!
If someone figures out a somewhat easy swap, LMK!
