Downshifting
Old Jul 12, 2009 | 01:16 PM
AlabamaGuy's Avatar
Default Downshifting
Just got my MCSS and love it. However, I noticed that it won't downshift to first until you get under 35 mph. Can this be tuned out to where if you're doing a higher speed it'll still downshift? In my Colorado, you could be doing a speed right up to redline in a lower gear and it would still downshift and run what little was left.
Old Jul 12, 2009 | 01:30 PM
TiredGXP's Avatar
Yes, you can change the shift tables to increase the downshift speed
Old Jul 12, 2009 | 01:37 PM
AlabamaGuy's Avatar
Good stuff. Now, on a MAF engine, does it matter much if you do Bolt-ons after the tune or before? Seems like you're just changing A/F rations withthe tune and the engine is making those happen no matter the conditions. Am I thinking correctly here?
Old Jul 12, 2009 | 02:53 PM
TiredGXP's Avatar
No.
The MAF curve is set to define X amount of airflow per Y Hz of signal. While GM does a substantial amount of research into setting their MAF curve, there is variability in production. Up to a point, the fuel trims can compensate for the MAF being off, but STFT's disable when you go into open loop, and the LTFT's lock into their last value--who knows what AFR you actually get at WOT in this situation.
You really need a wideband and to tune your MAF and VE whenever you make mods that can affect airflow.
Old Jul 12, 2009 | 03:14 PM
AlabamaGuy's Avatar
No.
So waiting until after intake/exhaust would be more beneficial?
Old Jul 12, 2009 | 09:28 PM
Panther427's Avatar
Yep 1111111111
