Upgrading Spark Plug Wires
Old Jul 20, 2009 | 02:21 PM
DP 08 GXP's Avatar
Default Upgrading Spark Plug Wires
I am going to be upgrading my plugs and was just wondering if any of you had upgraded your spark plug wires and if so what brand did you get and where from? thanks.
Old Jul 20, 2009 | 02:27 PM
neilownz's Avatar
I have taylor ones for my car and truck. Thundervolt 50s (part 98005) and Pro 409s (part 79205 for red and 79605 for blue). They ran like 70-80 a set from an online vender.
Old Jul 20, 2009 | 03:01 PM
DP 08 GXP's Avatar
which part number works for the LS4's?
Old Jul 20, 2009 | 04:25 PM
Brian396's Avatar
MSD pn# 32819 they are for a LS1. The length was right, but the #8 boot is hitting something back there. Next time I'm out side I'll check to see if it is wearing into it.
How is the #8 with the taylors?
Old Jul 20, 2009 | 05:42 PM
neilownz's Avatar
Seems to fit. I have the red 409 10.4mm ones in the car. I haven't really checked if it's worn or hitting anything.
All of the pre made LS coil based ignition wire sets should work. There shouldn't be too much of a loss if you go with a 8mm since they are so short. Stock ones are capable too.
Old Jul 20, 2009 | 06:06 PM
Pauls325's Avatar
these are the ones im going to get http://www.summitracing.com/parts/MSD-32813/
Old Jul 20, 2009 | 10:47 PM
DP 08 GXP's Avatar
just put my order in for the taylor 409 wires.
neilownz: you will have to let me know if you find any wear or if its hitting anything.
Old Jul 21, 2009 | 07:47 AM
neilownz's Avatar
Alright. I can take pics this weekend maybe. My new valve covers are finally on too. That was a bitch of a job.
Old Aug 1, 2009 | 09:11 PM
Mels SS's Avatar
I want to see the valve covers!!
Old Aug 1, 2009 | 10:28 PM
williamGT's Avatar
me too.
Old Aug 1, 2009 | 10:33 PM
neilownz's Avatar
Maybe tomorrow.
Old Aug 2, 2009 | 08:41 AM
Mels SS's Avatar
Its tomorrow lets see them.
Old Aug 2, 2009 | 02:05 PM
neilownz's Avatar
Ok here you go.
Attached Thumbnails Upgrading Spark Plug Wires-dscf0028.jpg   Upgrading Spark Plug Wires-dscf0029.jpg   Upgrading Spark Plug Wires-dscf0030.jpg   Upgrading Spark Plug Wires-dscf0031.jpg   Upgrading Spark Plug Wires-dscf0032.jpg
Old Aug 2, 2009 | 03:38 PM
Mels SS's Avatar
Very nice
Old Aug 3, 2009 | 06:56 PM
DP 08 GXP's Avatar
hey neilownz when you were takin pics of your valve cover did you find any wear on the #8 plug wire?
Old Aug 3, 2009 | 07:27 PM
neilownz's Avatar
I didnt, but it is pretty hot under there after its been running for awhile. The oil cap gets warm now. Found that out changing the oil the other day.
Old Aug 19, 2009 | 04:22 AM
williamGT's Avatar
why are the wires longer than stock one? I want red 8.5mm msd's but they look long.
Old Dec 10, 2010 | 09:03 PM
smokin06impala ss's Avatar
Any updates as to the 10.4mm wires having any signs of wear or hitting anything? I'm thinking of buying them.
Old Dec 11, 2010 | 01:21 PM
RedHotG8's Avatar
Aftermarket wires won't give you any more power so you're better off using the stock wires. Same goes for plugs, unless you are putting out a lot of horsepower.
Old Dec 11, 2010 | 01:52 PM
DP 08 GXP's Avatar
he is correct...save your money and stay with OEM
