ABS, traction control and stability control warning
My wife just called and said that as they were driving down the interstate the car dinged at them ABS, traction control and stability control warning. luckily it's under warranty but i sure hope they get it right the first time. I'd trade the damm thing in but it's got no value right now. it's an 08 GXP
Mine does that but it's an electrical problem, I have a bad wire in my cutout. Does the power surge too, i.e. lights dims, radio stop, and doors unlock and relock? Mine's even died for a split second... I really need to fix that wire...
ha had the same problem with about 30 or so k miles on my 08, took it to the dealer 4 times they just kept throwing parts at it (it was under warranty) turns out the ecm wire was loose or something and everytime the wire hit the piece of metal it would cause the code... so ya... dealer should help ask them to check that too... most of the time they just look at the code then throw the part at it and call it day they dont really troubleshoot that much unless like i said it keeps coming in all the time.
mine did this and it was the left front wheel hub bearing.
they also replaced all my speed sensors
they may have done something else but those are the two big things
it was a grand total of a 1,000 to pay them
My wifes car does that and we are on our 2nd round of wheel hubs. Our cars and the fwd 3800's eat wheel hubs after the factory ones **** the bed. Timkin and oem wheel hubs are the best for these cars. The first time we tried cheapies and failed after a month. Live and learn I guess.
-Mike
-Mike
I had this come up pretty recently on my Monte. I replaced a line leading from the master cylinder to the ABS splitter and caused a large amount of air to be introduced to the system. After I bled the brakes, the warning went away.
