Old Sep 4, 2009 | 06:48 PM
Mels SS's Avatar
Default ???
How do I remove the plug wires from the plug?? I tried to remove them and the wont just pull off.
Old Sep 4, 2009 | 07:01 PM
bore.me's Avatar
it helps to get mad at them and pull like hell... or you could try a puller tool
Old Sep 4, 2009 | 08:47 PM
94ss06gxp's Avatar
did you try adding a little twist to your pull? it usually makes them come off easier... if not try a puller tool
Old Sep 4, 2009 | 09:32 PM
Mels SS's Avatar
Why would it be that hard?
Old Sep 4, 2009 | 10:40 PM
neilownz's Avatar
GM was saving by not putting dielectric grease on them.
Old Sep 5, 2009 | 08:38 AM
Mels SS's Avatar
So just keep pulling?
Old Sep 5, 2009 | 10:10 AM
bore.me's Avatar
Yeah just keep pulling. If might be hard to fit a puller tool inside the engine bay but you could go see what your local auto parts store has to offer. Sometimes the wire boots are just really hard to get off and the only solution is a strong set of hands and fresh muscles. Anyway when you replace them be sure to put some special dielectric grease on them so you don't have this problem again
Old Sep 6, 2009 | 09:41 AM
Mels SS's Avatar
Got the wire off it has dielectric grease on them just took a little different angle to remove them.Why does it have the metal around them and that spring? Is the metal some type of heat shield?
Old Sep 6, 2009 | 01:48 PM
neilownz's Avatar
Yea. You can get little booties from taylor for them that are made out of nomex or whatever, but I haven't had a problem with mine burning. I think it's good to 600 degrees without and like 1200 with them. 2560 is the part number for the black ones and 2562 for red.
http://www.taylorvertex.com/Products...rcatalog30.pdf
Old Sep 6, 2009 | 04:48 PM
Mels SS's Avatar
Thank You!!
Old Sep 7, 2009 | 09:23 PM
Rossko85's Avatar
if you want to spend your money on them.....they look cool, but it isnt going to get you anywhere in the heat shield or performance dept. LOL I like the "look cool" aspect myself...and it can never hurt...they go on..they look good...and they work, regardless if we need them LOL...
Yeah, those wires....LOL be careful...cause the more you just pull like hell on them, especially if your thinking of taking them in and out, like we did to read the plug itself..the dam sleeve come completely off!!! we had to rebuild it LOL...so be careful..the grease is a great idea...
Old Sep 8, 2009 | 11:13 AM
Mels SS's Avatar
Thanks Guys!!
