LS6 Manifold Idea
Any thoughts??
thanks
https://ls1tech.com/forums/ls4-front...s2-intake.html
GM oil pan oil routing block off plate. Mounts on oil pan to route from oil filter to block. Fits all factory LSx oil pans. This block off plate has a threaded hole for provision for a sensor or oil feed. M12 threads.
In it's threaded version, it is a C5 Corvette part. There is a version that appears in trucks where the boss is unthreaded, which would be more suitable, since you can thread it for your sensor application.
If it's threads were smaller, the CTS-V temp/pressure combo sensor would be the plan. It's thread's OD, however, is almost as large as the OD of the boss on the cover.
What brought me to this forum was an LS7 manifold search that I was doing.
It seems that on here, there is a misconception regarding the LS7 manifold fitment. Sorry, guys, as it only fits the LS7 heads which, in turn, only fit the 4.125 case.
