Thorley Header Project Update
Old Mar 23, 2010 | 08:57 PM
  #881
CenTexSS's Avatar
Negotiations to get it back? There should be no question about getting your money back!!!
Did you pay with a credit card? If so, dispute the charges.
Old Mar 23, 2010 | 10:02 PM
  #882
gulfstreamcpt's Avatar
Originally Posted by Mgpeagle
AG,
It isn't the extra stuff I need to buy that aggravates me it's that I was charged twice for one set of headers. It seems like every time I do something that is on the expensive side for my car something gets messed up. Honestly, that's the crap I am talking about. 25 bucks here or there is one thing, 650.00 is another...
-Mike
Hey Mike;
Don't feel bad or like the Lone Ranger. I was double charged as well. Got the first original charge on the 17th and then got another "pending authorization" on Friday that I watched all weekend that did turn into an actual charge this morning. I called Nick there and he was very appologetic and said that they had already credited back my amount. It sounded like they knew of other "double charge victims" and that they were correcting them as well. I would assume you will be one of those. Told me my credit should be to my acct in a day or so. It sux, yes, but at least they are right on it getting it taken care of.
My box showed up today BTW. All you lucky bastards at least get to be home and meet the UPS Man with your new present. I'm out on the road for work and won't be home for another week or better, so don't even get to see mine for quite a while.......
Old Mar 24, 2010 | 04:04 AM
  #883
07carlocrusader's Avatar
Default Crusader has his!! But a question!?
I have recieve mine about 6-7 hours ago! They look beautiful! But of course I tend to do a "dry run" through the instructions and I noticed under "The Disassembly Instructions #14" says: "cut down factory down pipe approximately 1/2 before weld on the catalytic converter"
Here's the question(& proably a stupid one): Would cutting a 1/2 before the cat basically means deleting a large amount of the DP??[/B]
& if so; is there any point in ordering a Hogan DP?
Well here's some of my pics:
Old Mar 24, 2010 | 06:35 AM
  #884
williamGT's Avatar
What do you think about the flex pipe? Should we put another one on there?
Old Mar 24, 2010 | 07:16 AM
  #885
I hope your not asking me my friend!! LoL!! I don't understand it! Instructions #8 9 10 are also confusing.
Example: #8 says "remove the transmission dip stick and secondary crossover once again in preparation for a full weld" ??
#9 says: "once the cross over/head pipe has cooled you may now paint the weld with a high temp paint and re-install on the vehicle." ??
I guess what I'm also asking here is: isn't this the only "welding" for this location/application that I have circled below and will this same cirlced location of the "welding" explains the: "cutting the down pipe to 1/2 before the cat" in Disassembly Instruction, # 14??
Which would conclude that we basically no longer really need a down pipe??
Old Mar 24, 2010 | 07:44 AM
  #886
williamGT's Avatar
I didn't even look at the instructions yet, I gave it to my mechanic to read to look at he's dealing with.
Old Mar 24, 2010 | 02:58 PM
  #887
Sittingmongoose's Avatar
shouldnt it have been 600 not 650?
Old Mar 24, 2010 | 03:13 PM
  #888
higsy's Avatar
shipping costs added ?? Just got mine. Hope to see some pictures or vids etc.
Old Mar 24, 2010 | 04:03 PM
  #889
Mgpeagle's Avatar
Gulfstream,
They did that to me on the very same days. Since I haven't heard back from them in 3 days, I finally went to my bank so they can dispute this with Jardine Performance. One way or the other I WILL get my money back. I feel if someone screws up then take care of it. Don't make people wait for monies that they deserve. Now a days money is getting harder and harder to come by. Sorry for the rant, I just expected thier customer service to be better.
-Mike
Old Mar 24, 2010 | 04:15 PM
  #890
94ss06gxp's Avatar
by the sounds of it the header are a little more PITA than expected , kinda glad i didnt order, especially when money is tight, for sure couldnt afford to be charged twice.
Old Mar 24, 2010 | 04:22 PM
  #891
jabronie78's Avatar
Sounds like it would be a bitch to weld it when its installed.
Old Mar 24, 2010 | 04:28 PM
  #892
ji22my's Avatar
I got my headers today, and I think they turned out great. A lot better than I thought they would be. They look so good I dont care if I have to pull the engine out to get them on. I cant wait.
Old Mar 24, 2010 | 04:54 PM
  #893
StealthV8's Avatar
is it too be welded when they are on? sounds like the instructions say to test fit then pull it back out to do the full weld
Old Mar 24, 2010 | 05:47 PM
  #894
Rossko85's Avatar
Im so excited for you guys!! want some dam videos!! Those sure are purty!!
Old Mar 24, 2010 | 05:52 PM
  #895
jabronie78's Avatar
Yeah I guess you are right I misread the other post
Old Mar 24, 2010 | 06:08 PM
  #896
Negative, I called them earlier and they told me the only weld is down 1/2 right before the cat!!
ATTENTION:
He also said THERE IS NO NEED TO BUY A AFTERMARKET DOWNPIPE!!!!
Simply because you are cutting all your downpipe off, just as a suspected!
As I studied and studied (LoL!!) I noticed that the back headers DO drop down in down pipe fashion already!! Thorley Performance over the phone confirmed this!! So please do not even think about buying a down pipe for this application cause you won't need it!!
Old Mar 24, 2010 | 06:20 PM
  #897
StealthV8's Avatar
ATTENTION:
whenever i get these, i'll be using part of my aftermarket down pipe because i don't want a cat and piping from the headers to the exhaust will be 3" with the aftermarket pipe but with the stock one it will be smaller.
  #898
higsy's Avatar
ATTENTION:
I already have a hogan downpipe I was planning to use. Wouldn't the highflow cat be of more benefit to use with that?? Also if using the stock downpipe when you cut it does it eliminate the O2 senser and crappy u bend? Can't remember if it's before or after the cat.
Old Mar 24, 2010 | 06:25 PM
  #899
mike690003's Avatar
Will the heat change the color of these headers?
The finish looks awesome!
Old Mar 24, 2010 | 06:32 PM
  #900
BuickRacer's Avatar
Here's what my downpipe currently looks like; this was after Thorley had reinstalled the OEM manifolds during the mockup phase...you can "kind of" see how long the inlet to the cat is...
Attached Thumbnails Thorley Header Project Update-inletpipe2.jpg   Thorley Header Project Update-xover.jpg
