Help me sort out whats true
I had an interesting conversation with a guy who is supposed to know his stuff so lets see if he knows some stuff we didnt know before.
-The ls4 is acually the LQ4, the ls4 doesnt exist.
-Heads will never decrease power from being too big.
-I am losing power from my 1.8 rockers because my cam's and heads geometry is not designed for 1.8's. If i put back my 1.7 rockers, i may gain power.
-We can not simply snip the dod wire off even if dod is disabled becasue it needs to be a closed circuit, if we do, the engine will go into limp mode. I asked if we could just use a ls2 vally cover and he said that you will still need to connect that male dod wiring harness so something.
the lq4 is the iron block version of the 5.3, ours is all aluminum. yes, the ls4 is real designation. too large head ports will decrease average horsepower below the curb, will increase peak hp at higher rpms. don't know about the rockers. your heads are just a tad too large, its not like the boss cleveland heads on the boss 302, now those heads were big. stock, they were slugs but put in some 4.30's on the back and that mustang could outurn a hemi cuda.
There's a bit of mis-information in what you were told.
Yes, heads that are too big can decrease performance. When it comes to efficiently filling a cylinder many factors come into play - RPM range; valve size, lift, timing and duration; port size; exhaust back pressure, intake manifold design...
Limiting the discussion to the intake side, it's important to note that the intake valve is open for a considerable time after BDC, perhaps 45* or more depending on the cam. In order to keep air flowing into the cylinder after BDC (or at least to keep it from being pumped back into the intake) you need both positive wave pressure (determined by the length/shape of the intake tract) and momentum of the air moving past the valve. Excessively large ports slow down the intake charge, making it more susceptible to reversion. The larger the cross-sectional area of the intake ports, the higher RPM required to maintain velocity.
The impact of excessively large ports is to decrease cylinder filling/power at low- and mid-range RPM's. Large port race heads are probably not what you want for a street driven engine that spends most of it's time below 4k RPM. The $2,500 question is what are the right size heads for the application?
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Edit:
Rocker arm geometry is determined primarily by pushrod length, not the rocker arm ratio. Higher ratio rockers provide quicker valve opening, more lift and more total flow area.
Next thing you know, this guy is going to say that you need backpressure to develop torque.
Edit:
![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
Edit:
Next thing you know, this guy is going to say that you need backpressure to develop torque.![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
Edit:
You never need backpressure.
When it comes to generating torque, the name of the game is airflow. Backpressure is the result of restrictions to airflow and reduces volumetric efficiency.
Think about it - an above atmospheric pressure in the cylinder at the end of the exhaust stroke, just when the engine is trying to bring in a fresh charge to the cylinder, means that you end up with a smaller, more diluted charge of air and fuel-->therefore less fuel to burn and less pressure is produced on the next power stroke. Less pressure=less torque=less power.
Tuned exhaust systems work because, within their RPM limits, they create a slight vacuum in the cylinder at the end of the exhaust stroke. At other rpm's they may create additional backpressure. I haven't been through all the math, but the Tri-y design is apparantly effetive over a wider rpm band than long tubes, but are more effective at lower RPM's as well, which is probably why you don't see them too much on drag cars.
I've been doing a fair bit of research into turbo's for the Fiero project (3.2 turbo) - I'm generalizing a bit here, but while the turbo's turbine wheel and housing create backpressure, what the turbine needs to function is air velocity. Reducing the A/R ratio of the turbine housing speeds up the airflow across the turbine wheel, but at the cost of restricting overall airflow. Small A/R ratio's give boost early, but choke the exhaust at higher RPM's, limiting overall power production. Larger A/R housings create less velocity, less backpressure, but take longer to spool up, ultimately more power is available at high RPM. Similar effects exist with turbine wheel size - smaller turbines spool quicker, but have a limit to the amount of air they can flow.
Backpressure is not a good thing for overall power production with a turbo either, but there you go, more trade offs--> have the turbo give you a fun, quick boost at low RPM and then go flat or get maximum power coming on just when you need to shift. In reality you size the turbo to avoid either extreme.
and sorry for the lecture
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
There is a sticker somewhere, in my case it is in the trunk under the carpet, that lists all of the RPO's for your car and LS4 is definately there. Your VIN also references LS4 if you look at the official GM VIN decoder.
As to heads being too big, it all depends on the rest of your combo. There are no absolutes in hot rodding.
The whole point of changing to 1.8s is to alter the valvetrain geometry, and in a way that dyno tests repeatedly show to improve power.
But, here's why I posted: he is way off about the DOD connector. There are five wires, one for each solenoid and one common ground. The ECM needs to output some voltage to energize the solenoid to disable the lifters for that cylinder. There is a DTC for each cylinder, and they can be disabled in HP Tuners. Even if you didn't disable the DTCs, I doubt the ECM checks for the presence of a solenoid until it tries to actuate it. But let's say it did... you could still fool it with a resistor. Even if it ran the most exotic diagnostic check known to man, you could still fool it with an impedance. Just disable the diagnostic check when you get tuned up and forget about it.
from everything i have read there is such thing as too little backpressure if you are teying to optimize the scavenging effect of the exhaust but seeing our exhaust manifold and dp setup i would say go for it i remember hearing that our cat needs a cartain ammount of backpressure to operate though...
