Tran failure (nothing new) Possibly saying good bye though..
#48
Yeah... With out a tune just the Downpipe or just the K and N will be enough to upset the shifting. I tried just one and then the other separately and I had a tie up at WOT on the 1-2 shift. Basically the engine would hit the governor then shift. If you go back to stock the shift control should return to normal.
#49
Hey man, off topic but your ride is lookin' cleaannn in that sig pic!
Yep, just what I figured. There is this awkward momentary pause...I know its torching my tranny and its basically gonna eat it sooner rather than later. But at this point I would have to automatically step down to something not as nice car wise because of a student loan....ouch.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#50
But back on to topic,that would suck to step down from the Monte to a bucket....Hopefully a shift kit will help me out for a while,good luck with your tranny...
#51
If I'm reading this right, it seems like the root cause of a transmission dying with very few mods is actually easily explainable? It sounds like the extra power (which causes the torque converter to stall a little higher) combined with the stock shift speeds (it shifts based on mph, not RPM) and rev limiter leads to a more jarring 1->2 shift, which at first isn't as noticeable but over time takes it's toll on the transmission. Is that everyone's experience?
#52
#53
x2 as soon as i hop in "auto light control OFF, TC OFF"
im experiencing similar, from D to R or R to D i usually just tap the gas a couple of times reving it before actually going or else it will feel like its stalling..
and few times its happened were when it shifts at low speeds it will hesitate, rev up (car doesnt go any faster) and stall a bit then pull u back in ur seat to the rpm it was at..
and like nacho, when going wot from 1st to 2nd idk if its the same as nacho but mine lags like his a bit but i feel a small shake in the car, nothing noticable, but as a driver youll feel it..
#55
#56
Characteristics of our setup: With DOD enabled, the transmission controller will release the TCC, engine speed will momentarily flare and drop as the tcc reengages. The TCC is also on partial engagment while not on a relativley heavy cruise load, so any throttle changes will cause a momentary engine speed flare, till the converter can be repressurized. The clutch in the converter is made of a special material to handle this operation. Also the shifts are naturally soft on normal use, and are actually relativley hard at WOT, the driver really cannot feel it because the torque converter, being as loose as it is, absorbs quite a bit of the shock. If you drive one of our V6 counterparts you will know this, as the V6's have a MUCH tighter converter and you can feel the shifts in that setup.
This is not a weak transmission per say but if a retune is not done after a significant modification, it will not shift correctly. Keep in mind, these irregularites may not be noticed by the seat of the pants.
Also keep in mind, if you ruthlessly beat on ANYTHING long enough it will fail. If not the transmission in our cars then its the rear ends hopping out of an old CTS-V or a Cobra Mustang with IRS. At least we dont have any wheel hop....
I still have my 3 inch catted downpipe and my K and N Filter Charger kit, one day maybe I'll get some money and buy a tuner, then reinstall those two pieces again. 65,000 miles now, I need to start gathering parts for a tune up, plugs, wires, belt, pulleys and tensioner, coolant, bar's leak, waterpump, thermostat with gasket, radiator and heater hoses, transmission filter and fluid. And maybe if I can get into the fuel tank, I'll change the fuel filter as well... if it is even replacable.
#57
Well it hesitates coming out of turns, like the engine is taching off some revs but it doesn't feel like the car is moving.
From a stop/low roll shifting out of first is pretty laggy too, if I had to describe it the RPMs approach the red line and there's a momentary pause where the car is in between 1st and 2nd and the pitch of the engine climbs before it grabs 2nd. Don't know if that is just how it works or I'm willing to guess my tranny is on the outs.
#59
OP Here with my update.
The dealership replaced mine with a new transmission, no hassles. They just did it. I was amazed. Not trading in my car, due to recent events. Any money i had for the trade in went towards a medical emergency i had. Considering that i didnt have to pay for a new tran. i'll keep the car and send the tran over to the guys at TEP. not anytime soon, but eventually.
#60
@ Count of Monte Carlo, I like the way you spelled that out. There's manufacturing variability and our engines produce enough power stock that it doesn't take a lot more torque to push the limits of the stock transmission, but a CAI and downpipe leading to a failure at anything less than 100k always seemed odd to me. The 3800 guys know that much above 300HP you are asking for trouble if you drive it hard, but most of them have transmissions that have already seen at least 100k and generally the failures happen after 130k-ish (from what I've read anyway). There are plenty of GTPs running fine at 200k. Also, in stock form our ECM/TCM combo protects the transmission much more aggressively with torque management than the PCM in the GTP/GTs does.
Would you consider putting that post in a new thread along with some practical limits on the stock input shaft and stock chain? We could then ask the moderator for a sticky. The information on this page from TEP is also incredibly useful in answering common 4T65HD questions:
http://www.tripleedgeperformance.com...sion_Info.html
Everyone can also check out grandprixforums.net and look for Trannyman95's posts in the transmission sections for help. If we start sending him enough business, maybe he'll keep one of our transmission housings in stock so that we can do a cross mailing like the GTP/GT guys can.
