LS6 Intake Manifold Project Update
Old May 16, 2010 | 11:00 PM
  #41
Haulin_Ls4_GxP's Avatar
Originally Posted by AlabamaGuy
Now somebody figure out if this is gonna work or not! LMAO!
Please know I do understand that and I like the fact I can get on here and see what people are doing so I can do the same to make more power and I appreciate that I really do. Maybe your right he might not have met to come off that way but that’s how I took it. I’m not one of those people that can just take my car apart and throw something on not knowing it will for sure work. That’s why I checked the tb first because I didn’t want to be wrapping the swap up and it not work.
Old May 16, 2010 | 11:08 PM
  #42
AlabamaGuy's Avatar
Understand that. The SS is my daily grind. I was just saying forgive and forget and let's all work together to figure this thing out. It's all cool
Old May 16, 2010 | 11:57 PM
  #43
Old May 17, 2010 | 06:56 AM
  #44
Tappeter's Avatar
Hey, sorry if anyone took offence. It was not my intention at all to be condensending. I was just trying to explain as clearly as possible what I did. Its sometimes hard to put a complicated proceedure into words so others can understand what your talking about. I will try to choose my words more carefully I guess.
Please let us know what happens when the 5 volt references are switched so I can fix my cable.
Old May 17, 2010 | 09:46 AM
  #45
neilownz's Avatar
The grounds might matter too. Don't know.
Old May 19, 2010 | 10:25 PM
  #46
Tappeter's Avatar
Any luck with the adapter cable, getting it to work?
Old May 19, 2010 | 10:32 PM
  #47
DavidGXP's Avatar
WTF? Adapter cable?
Old May 20, 2010 | 06:14 AM
  #48
Tappeter's Avatar
Wiring Adapter cable to use Truck TB on LS4 engine, any luck making it work??
Old May 20, 2010 | 08:53 AM
  #49
I will be working on it tonight so I will let u know
Old May 20, 2010 | 02:42 PM
  #50
AlabamaGuy's Avatar
*waits patiently*
Old May 20, 2010 | 07:35 PM
  #51
ok so this is what i have tried and got nothing
a-e
b-c
c-f
d-h
e-g
f-d
g-a
h-b
a-e
b-h
c-f
d-c
e-b
f-d
g-a
h-g
a-e
b-c
c-f
d-h
e-b
f-d
g-a
h-g
mother ****** **** *** bitch *****
Old May 20, 2010 | 08:24 PM
  #52
AlabamaGuy's Avatar
Hmmmm
Old May 20, 2010 | 08:53 PM
  #53
neilownz's Avatar
Anyone with a GXP service manual?
The only thing I can think of is if we need to use like a modified Dr X harness.
Old May 20, 2010 | 09:08 PM
  #54
here you go
Old May 20, 2010 | 10:44 PM
  #55
Tappeter's Avatar
How are you testing the cable to see if it works? I was told that if the key is turned to ON , without starting engine, that the stock TB will actually operate. Is this true?
Old May 20, 2010 | 10:47 PM
  #56
Tappeter's Avatar
I wish I knew an electronics wizard, I am getting lost, maybe time for an aluminum TB adaptor and use the stock TB.
Old May 20, 2010 | 10:49 PM
  #57
Trans Am Jam's Avatar
Thank you, you are obviously intelligent and good looking! lol
hahahaha
Old May 20, 2010 | 11:09 PM
  #58
DavidGXP's Avatar
TB adapters will be ready soon. I've got 10 coming. I told my designer to make them no more then 2" thick, and once we had the dimensions he said no problem. He even said we could go thinner, so I said make it as thin as possible. So he took down the specs, made a carbon copy of both tb's and traced out the pattern and marked the holes. Next he made the adapter out of wood and now he his going to cast 10 or more. I'm not sure on the price. But once they are ready I'll let you all know and PAypal will be the only choice. The machinist said he can build them cheap, but in order to get his attention I told him that tb spacers were going for 100.00 and he said that's too much so we shale see! For anyone interested send ma a PM and I'll send you my number. Send me a text and I'll send the paypal info. Once ready!
Old May 20, 2010 | 11:18 PM
  #59
neilownz's Avatar
5v ref 1 and 2 both go to the accelerator pedal position sensor.
Only 2 seems to go to the throttle body. (page 9-606)
pin/wire color/circuit/function (page 9-639)
A D-GN 485 TP Sensor 1 Signal.
B L-BU 6295 5-Volt Reference 2
C TN 2752 Low Reference
D PU 486 TP Sensor 2 Signal
E YE 581 TAC Motor Control - 1
F BN 582 TAC Motor Control - 2
G GY 2701 5-Volt Reference 2
H L-BU/BK 6297 Low Reference
We need to find out what the truck pedal/tb schematics look like.
Old May 20, 2010 | 11:20 PM
  #60
AlabamaGuy's Avatar
Form a raiding party and head toward the Vortec forums...
