LS6 Intake Manifold Project Update
Only 2 seems to go to the throttle body. (page 9-606)
pin/wire color/circuit/function (page 9-639)
A D-GN 485 TP Sensor 1 Signal.
B L-BU 6295 5-Volt Reference 2
C TN 2752 Low Reference
D PU 486 TP Sensor 2 Signal
E YE 581 TAC Motor Control - 1
F BN 582 TAC Motor Control - 2
G GY 2701 5-Volt Reference 2
H L-BU/BK 6297 Low Reference
We need to find out what the truck pedal/tb schematics look like.
LS4 A Terminal volts TP Sensor 1 - 3.58v throttle closed and decreases as throttle blade is moved.
LS6 G Terminal volts TP Sensor 1 - 1.21v throttle closed and increases as throttle blade is moved.
I'm no electronics engineer, but the TP Sensor 1 difference must be the issue as it's a huge voltage difference and works opposite on each tbody.
TP Sensor 2 - this functioned the same on both throttle bodies. 1.44v closed on LS4 and increased as blade opened and 1.22v on LS6 and increased as blade opened.
So, I am waiting for someone to make an adapter.
I've never torn into a throttle body, so bear with me, but..
1. would it be possible to find this sensor in the TB and swap sensors?
2. Are there any extra unused pins at the connector that do provide the reciprocal voltage?
3. can the sensor be rewired (is there a third unused pin on the sensor)
