Denied a 13 second timeslip
Old Apr 18, 2010 | 09:11 AM
XFiveLiter's Avatar
Default Denied a 13 second timeslip
Try as I may I couldn't muster a 13.99. Best pass was a 14.04 @ 99.57 (2.18).
Car is completely stock except for a resonator delete and may have been getting some KR because I run 87 octane most of the time. There was about 50/50 mix of 87 and 93, so 90 octane?
Too bad I couldn't get better short times. Damn no-sixty-footin', wrong wheel drive car!
Old Apr 18, 2010 | 09:16 AM
1CL3ANSUP3RSPORT's Avatar
Not bad for a first time in a wrong wheel drive car,how many passes did you get?
Old Apr 18, 2010 | 09:20 AM
XFiveLiter's Avatar
I ran at least 10 times, the track was pretty dead and could have made 50 passes if I wanted to. I didn't notice them spray the starting line at all, just a little better 60 would have got me there.
Oh, and it's not my first time in a FWD car. I used to have a 99 GTP.
Old Apr 18, 2010 | 09:45 AM
Right on,my car is still a VIRGIN at the track maybe after I do the headers ill test it out.Yeah I forgot you had posted pics of your GP smoking the wheels at the track.
Old Apr 18, 2010 | 12:46 PM
CenTexSS's Avatar
Not bad for pretty much stock. Run with 93 octane, and I think you'll get it.
Old Apr 18, 2010 | 08:24 PM
Count of Monte Carlo's Avatar
Get some drag radials/ slicks, that will bring you down to zero slip and you'll better results.
Old Apr 18, 2010 | 08:27 PM
JP_GXP's Avatar
Zero slip and dead tranny...
Old Apr 18, 2010 | 08:46 PM
neilownz's Avatar
Just a reason to make it not stock anymore.
Old Apr 18, 2010 | 09:10 PM
I ran mine about 20 times down the track since I bought the car new. It can more than handle it.
Old Apr 18, 2010 | 09:22 PM
JP_GXP's Avatar
Radials or slicks? I always assumed this weak tranny would just explode with slicks, lol.
Old Apr 18, 2010 | 09:26 PM
The hard parts and clutches are not the problem directly. I see more going wrong with the pressure control soleniods and oil pump drive shafts wearing out.
Of coarse hammering on the equipment is not good either. Always preload any driveline if you can before flooring it.
I never slipped with drag radials.
