rocker suggestions?
Old Apr 30, 2010 | 11:39 PM
imnmbr1's Avatar
Default rocker suggestions?
What kind of rockers are you all running? Yella Terra 1.8s? What do you suggest? I'm thinking ls6 springs and some rockers
Old May 1, 2010 | 02:50 AM
Aaron_Provost's Avatar
I'm running Yella Terra 1.8s, I like them alot
Old May 1, 2010 | 10:07 AM
plmrass's Avatar
Hi im new here. I was thinking about doing rockers also but wanted more info on them. I had them on my 2000 gp and loved em so I figure they would be just as good for this engine. Will these mess with the dod at all?? Any help would be appreciated. Thanks Jeff
Old May 1, 2010 | 11:33 AM
DieselPump's Avatar
Rockers won't affect DOD.
Old May 1, 2010 | 03:01 PM
imnmbr1's Avatar
Were they worth it to you? Did you do springs too?
Old May 1, 2010 | 05:20 PM
Mgpeagle's Avatar
Yella Terra's if you go aluminum or SLP's if you go stamped steel. I would have went Yella Terra's if I didn't find a set of SLP 1.85's for 200.00. I also purchased some oil restricted pushrods to prevent valve float. I have stock WOT shift points and have no valve float with a 1.85 roller rocker with stock springs.
-Mike
Old Mar 30, 2014 | 03:47 PM
need4z's Avatar
I want to go with SLP 1.85 factory rockers and maybe new springs next month... can you reuse the factory push rods? SLP says on their website NOT FOR DoD ENGINES? ???????? So does everyone that has these or other higher ratio rockers turn off their DoD via tuning?? Still learning... sigh lol
Old Mar 30, 2014 | 08:30 PM
707chance's Avatar
Default rockers
I went with vincihiperformance valve train ls4 package. Information and performance results can be found on his site. I also added in a 056 boss cam.
Old Mar 31, 2014 | 01:42 PM
Mels SS's Avatar
What part numbers
