hp tuners, 06 LS4
trying to get all the basics out of the way first. just got the car (06 impala SS) it needs some basic maint, like plugs wires, im getting a p0420 code too so im going to check into that.
EDIT: I'm looking at my laptop and I see it right here. It's under trans->shift properties->desired shift time pattern. Check out the attachment.
Release 2.22 doesn't have any of the tapshift tables...
FWIW, I would not mess with the force motor current tables, because that lookup translates the line pressure command to a current. If you change that table, you no longer have any idea what pressure you are commanding.
I don't know this, but I think the transmission shifts hard when the MAP or the MAF fail because they are used to estimate torque, and all of the transmission pressure settings are based on torque. So if torque isn't known, the controller is set to a pressure that is safe for high torque shifts.
1.) shift time
2.) shift pressure
3.) torque management
4.) shift rpm
