DOD Cam Swap (formerly known as Preliminary Feedback On New Era G8GT Cam in an LS4)
#101
I think the cam is a little too big, but nothing that can't be fixed. Another trip to the strip is in order sometime soon to be sure, but I think I may have lost too much torque between 3000RPM and 4400RPM. There is just that dead spot where torque doesn't really climb. Drivability is great, there's plenty of torque below 3000RPM to putz around, and now that I've got the hang of this thing it's really easy to launch. For me, the high RPM torque peak isn't the issue, or even the revs. Actually, I love the revs.
Heads:
I need more static compression to compensate for the loss of dynamic compression. Obviously some porting would help too, but all I really need is some milling. I could probably go higher than 11:1 static compression and still keep dynamic compression safe, but I don't have the resources to try several different combustion chamber volumes. Besides, 11:1 is proven to be safe on cam'd LS engines, and you can generally still run a good bit of advance. I would keep the stock valve sizes to keep the valve weight down so I can safely spin this thing.
Valvetrain:
I could go with Ti valves and retainers, but that's not really necessary unless I really wanted to push my revs. At that point, I'd probably need Comp R lifters or something similar. This is where keeping the stock rockers really helps, because they are much, much lighter than all of the aftermarket rockers.
Bottom End:
The crank is fine, but the rods really see a lot of abuse with revs. I can change the rod bolts with the engine in the car still, and I'll probably do that before anything else. Aftermarket rods would be next if I wanted to keep reving the engine, and maybe pistons if I wanted to fog it.
N20:
The universal "it's not fast enough" fix. While a 150 shot would be fun, I'm thinking that I wouldn't need much more than a 25 shot, maybe 50, to help below 4800RPM. If you've ever seen what N20 does to a torque curve, you know that you get a nicely fattened torque curve right when you hit the button. With my oversized (but easy to fit and install) injectors, I'd have plenty of room for a small dry kit. That wouldn't stop me from using a much larger wet kit later if I ever decide to get serious about racing the car.
Cubes:
A whole different approach would be to size the engine properly for the cam. This would be really expensive, and I've got a 12.5:1 351C looking for a rat rod that I would spend the money on first. I only have about $2600 in the motor right now, and a little over 5k total if you add in the trans and HP Tuners. But just for fun, I think that an L76 or L99 long block with the LS4 crank and accessories could be made to fit using the correct transmission adapter plate.
Gear:
If I do any of the other stuff I just listed, my 3.29s will be fine.
Finally, I could just go with a little smaller custom grind. I think Sittingmongoose's cam would be about perfect. But for now, the car is still more fun to drive.
Heads:
Valvetrain:
Bottom End:
N20:
Cubes:
Gear:
#102
sounds like your on the right track and just about dialed in. a little head work with some compression and you should be good to go. 3.69's with an 3200-3400 stall (depending on your peak tq rpm) should really wake that beast up! be careful with those stock dod lifters and if you do end up pulling the heads then you might wanna do a custom cam and say screw dod. when you do go to the track please get some tires that will help your launch
275's fit perfect!
275's fit perfect!
#103
It's definately coming together, and thanks to everyone for the support! I'm for sure gonna run 275's next time, but I've got a lot of tread left on my tires. I'm not in any hurry to have everything I want to do finished right now. I'm going to enjoy my slightly over cammed engine for a while. I would have prefered not to do the headers and cam at the same time, but it just made sense to put the headers in when I did the cam. Maybe next spring I'll do the heads, but for the moment this is my last mod:
I'm still going to run the car at the track and play with fuel and spark, and I'll post times even if they suck. I shouldn't have trouble hooking anymore though, because I've got the ECM mostly sorted out and I'm used to how my car drives now. I would go tomorrow if the weather was nice, if my wife wasn't having early contractions. I might dissapear for a while here pretty soon.
Since I was crawling under the car earlier to get pics for Curt, I also took a pic of the cutout:
#104
Great job man, my hat's off to you. This should be renamed "How to Cam Your LS4," there's some really good, useful info for people in here that you and JDMC5 laid down.
#105
thanks NACHO.
I love the Pic of the baby seat hahaha, welcome to my hell!!! J/K, your gonna love being a dad.......after about 4 months, 300 diapers, 120 sleepless nights and half your hearing gone......and then the teething starts. Ok I'm done messin with you.
I agree, the bump in compression, or swapping cams altogether (which would be a nightmare) is about all you can do to increase power between 3-4K. You could bump it up to 12.0:1 and run E85 though. Porting and bigger valves will give you a little in that range but more in the topend. You could always go with a stall and bigger gear but kiss your traction good bye and I know that's not the route you want to go anyway. And as always you know I'm a huge fan of the spray.
#108
Regardless of the cam specs, if you are looking for a DOD cam and you don't want to really spin the motor I'd call New Era and ask for the high lift grind scaled down by 4 degrees or so. Everything would fall in line then.
For myself, I'd rather build the engine to be able to spin rather than use a smaller cam. That said, I may end up messing with the cam again, but only to advance it 4 degrees. That would move the intake valve closing point closer to ideal. The cam would still be "too big," but like I've said before I have more than enough low end torque to lug my Grand Prix around town. Here's an outstanding post by Patrick G with some research from SAM (2nd to last):
https://ls1tech.com/forums/generatio...ifference.html
I PM'd him, but he didn't know of anything similar for the 5.3L. But, just looking the numbers, it seems like whatever intake valve closing point would be optimum on a 6.0L would be about 3-4 degrees too late for a 5.3L. I think advancing the cam 4 degrees and bumping up compression will do wonders for my mid range torque.
My final note is that you can easily use David GXP's approach of clearancing an LS6 or LS2 fuel rail by grinding on the alternator bracket (although if you start failing alternator pulleys or belts, you could make a good guess why) and bending the fuel line to mate to the rear fuel rail entrance point. I'm sure that LS2 injectors would buy enough room for good fueling and cost less, although I should point out that the LS2 injectors are different from LS6 and LS4 injectors and require an LS2 fuel rail. The good news is that LS2 injectors have the same connector as LS4 injectors, so you don't need to modify your wiring harness. I would also like to point out that at these power levels the 90mm throttle neck of the LS2 intake might be beneficial, and that a ported LS2 intake can flow as well as the LS6 intake.
Good Luck! I can't wait to see this process refined by the next person that gives it a shot. Hopefully I won't look like too much of an idiot.
#109
As always, your posts are very informative Nate.
By the way, do you have the roof-mounted side curtain airbags on your vehicle?
I ask because I noticed some weird logo/symbol on your pillar.
#110
Yes I do. That was a key feature in my purchasing decision. This is my family/commuter car that I couldn't resist adding power to.
#112
your info and all the research has been very helpful and inspirational i think imma go ahead and follow along but go the low lift package and see the results.as for right now i kinda F**kd up cause i went ahead and bought some big *** rims lol
i just wanna hurry up and try and get this bigger brake kit installed.and i refuse to sell close to a thousand dollars in parts cause of some simple modifying. and then i will by my performance parts.
#115
By the way, the baby is home and happy! And now I'm back at work But, gotta make money to pay for all these diapers and wipes he's burning through!
#116
[QUOTE=nmp0098;13660104]
By the way, the baby is home and happy! And now I'm back at work But, gotta make money to pay for all these diapers and wipes he's burning through![/QUOTE]
congrats on the baby! and that is where all my car money went :
#119
So as not to derail the thread completely, I have some more feedback. I think I've figured out a good temporary answer to my mid-range blues: 12.2:1 AFR and 32* advance. It goes against conventional wisdom, but in the few free moments I've had lately I thought back to when I was tuning and remembered that it felt really strong at 12ish down low, and 13ish up top. So, I'm running 12.2 until the cam starts to dominate at about 4000RPM, and then smoothing up to 12.7 near the torque peak and keeping it flat (safety margin at high RPMs, even though there's more power by going leaner). Now it seems to pull hard the whole time. I can also see more air coming into the engine according to the MAF, so I think it is real. By the way, I'm running 28* up top (I don't have any PE advance to keep my life simple) because it doesn't knock (ever) and pulls strong. I can't tell a difference if I go to 26*, but at 22* it does feel a little weaker.
I'm also having a lot more success launching the car by just flashing the converter, so I'm going to try that the next time I go to the track.
#120
Back on topic, can't wait to see some more 1/4 numbers. Any plans on bolting on some traction?
