ssc lowering kit
Old Jun 12, 2010 | 09:35 PM
mike690003's Avatar
I'm lowered with 22" wheels, so if you have the right offset, you'll be fine.
Old Jun 12, 2010 | 10:55 PM
monte_with_a_LS4's Avatar
i have 37+
Old Jun 12, 2010 | 11:49 PM
06ImpalaSS's Avatar
Im not gonna lie Im pretty dumb when it comes to this kind of stuff. If I have stock SS wheels and stock 235/50/18 tires will I have a rub issue?
Old Jun 12, 2010 | 11:56 PM
chevySS08's Avatar
na your good look at the pics those are the stock wheels an tires bro
Old Jun 13, 2010 | 02:13 PM
06ImpalaSS's Avatar
I've been checking around and now think I'm ready to look at lowering the SS. Ive done a lot of reading here and on NAIOA. Some have replaced the struts some not. Some install the anti pogo washers others not. And some install the camber bolts, and again some don't. Some just install springs and thats it.
Right now I'm looking at SSC springs. As far as the struts go, I haven't felt any ride problems what-so-ever and haven't heard anything as well. I know you should look at starting to replace at 50k but im gonna try and get by a little longer.
As far as the anti pogo I would get the same that fit the Grand Prix, correct? Are they worth it? I saw them on ZZP for $30 for the set. As far as the camber I want to be safe and saw them on Rockauto for about $50 for 4. Any cheaper elsewhere?
If anyone wants to add anything that would be great. But from what I'm seeing this is the basic stuff I need. Again I'm going to try and get by with the struts. I'm at 45K so I'm thinking I can go a little while longer. If anyone knows where I can get the parts cheaper let me know as well.
Old Jun 14, 2010 | 08:53 AM
BuffaloSS's Avatar
That looks great. I know they guarantee these to not sag, but my *** end is a bit lower than that...so it may drop a little. I have absolutely NO wheelwell showing above the tire, with or without load in the back.
Originally Posted by JessmoMonteSS
Your Monte is looking real good with those springs! Has anyone installed these with 20'' wheels? Any problems with rubbing? I would love a set of these springs but I live in Upstate NY, which = pot hole hell.
I had 20" x 8.5", 255/35ZR20 tires, +42 offset, and rubbed pretty badly on the rear quarterpanel lip (which can be rolled to eliminate rubbing). Not sure if they would have rubbed with 245's, but I think they would have.
However, since I'm selling those wheels and decided to stick with stock (or another 18" setup), the ride around the city is pretty jarring. Not sure if the KYB's I have installed are shot, or if it's just the lowering, but it's pretty bad...you feel everything. It didn't seem so bad when the 20's were installed, but it's gotten progressively worse.
