XM Radio Problem
Old Jul 12, 2010 | 02:34 PM
DieselPump's Avatar
Default XM Radio Problem
Well I just subscribed to XM today, and all the channel names show up, but all I'm getting over the radio is static. I'm not hearing anything else other than that.
Does anyone have any ideas of what I could check.
I think it's a radio problem, because I've talked to customer service at xm and they're resent the signal a few times, but are saying since the channel names are showing up that it's most likely a radio issue.
Thanks
Old Jul 12, 2010 | 02:45 PM
Bryan921SS's Avatar
Ebay radio??
That's strange, if there is sound when you are using normal AM/FM then it might be a bad connection on the back of the radio....
Old Jul 12, 2010 | 03:01 PM
DieselPump's Avatar
It's the oem radio that comes in the monsoon system.
How would I go about getting the radio out to check the connection?
Old Jul 12, 2010 | 04:57 PM
Nick_Nasty's_GXP's Avatar
I couldn't remember what I did, but I think you might be able to pick another station to put the XM on???
Old Jul 12, 2010 | 07:03 PM
94ss06gxp's Avatar
first question, is it a seperate XM radio, or is it the built in factory with XM? next if it is the seperate radio unit, check and make sure the built in FM transmitter is on a channel you want it to be, the XM unit i bought did not come with a FM transmitter so i had to buy a seperate transmitter.
Old Jul 12, 2010 | 07:10 PM
He said it's the oem that came with the factory head unit
Old Jul 12, 2010 | 09:25 PM
DieselPump's Avatar
That's correct, it's the oem unit that come from gm.
Old Jul 13, 2010 | 07:04 AM
94ss06gxp's Avatar
thanks i guess when i read it it was just flying over my head
