Replace my XM sat to Sirius
Old Jul 20, 2010 | 11:57 PM
williamGT's Avatar
Default Replace my XM sat to Sirius
Hey everyone, I took out my XM radio, because it doesn't work this far up north, so I bought the SirGM1 module, It was quick to install but I'm waiting for the adapter plug so I can use the factory XM antenna. Thanks GXP25 for showing me this
Link to the same Idea of the install.....our cars has the single antenna plug.
http://forums.corvetteforum.com/c6-c...w-sir-gm1.html
heres some picks of the install.
Waiting on this plug, so I can use the factory antenna.
Old Jul 21, 2010 | 12:50 AM
blakss's Avatar
great link and lil install you got there.had sirius before but never looked into it.how much doe it go for now a days.?
Old Jul 21, 2010 | 10:22 AM
williamGT's Avatar
I bought mine on ebay, Impala and Monte Carlo needs this one, the one I have won't work on Imp/Monte.
http://www.tss-radio.com/products/gm...onnect-sirgm2l
Old Jul 21, 2010 | 10:25 AM
stoverz28's Avatar
Does Sirius have a stronger signal than XM or something?
Old Jul 21, 2010 | 10:33 AM
williamGT's Avatar
Yeah, northern Canada it cuts out alot.
This gives you an idea about XM vs Sirius.
Old Jul 21, 2010 | 10:53 AM
stoverz28's Avatar
So if I were to switch to sirius then my radio would cut out/ lose signal much less than it does now with my XM? I had no idea that XM's satellites were stationary.
Old Jul 22, 2010 | 11:42 AM
GXP25's Avatar
No problem. Glad it worked out for you!
And yes, based on your GIF, XM would be horrible for you without any efficient repeaters. I have reception problems here and there when facing South and West (especially with the blasted sunroof open).
They're geostationary, meaning that they rotate around the Earth at the same speed that the Earth rotates about its own axis. Therefore, it only appears that they are at a fixed position from the ground.
If they were stationary, they'd fall, lol.
Old Jul 22, 2010 | 03:47 PM
Kazmaniac's Avatar
Most annoying thing about XM - so you are saying if I switch to Sirius that fade out will not happen? I'd swap it out next week to get rid of that.
