Spark Plugs
Old Jul 21, 2010 | 05:43 PM
angevines08SS's Avatar
Cool Spark Plugs
Ok so its time for the tune up... what plugs n wires are you guys using or have found work the best and best place to buy them from...
Old Jul 21, 2010 | 05:51 PM
Nick_Nasty's_GXP's Avatar
The stock plugs and wires work great on the GXP. But IDK about the IMP or MCSS. It might be the same (which I'm thinking), and unless you need to run a colder plug, I would stick with stock.
Old Jul 21, 2010 | 06:13 PM
06MonteSS's Avatar
LS1Tech Sponsor
yep... ^ ^ ^ ^
no reason to deviate from stock plugs and wires...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jul 21, 2010 | 08:20 PM
Mgpeagle's Avatar
I run XP-104's. They are a 1/2 to 1 hr colder. It got rid of any knock I'd get. I would not suggest going any colder than this. I did and my gas milage suffered a bit. With the 104's I get better milage and no knock. It was a win-win for me.
-Mike
Old Jul 22, 2010 | 10:39 AM
scarlett's Avatar
I run the Bosch +4 platinum and they work awesome on my car, I also have MSD plug wire for LS1.
Old Jul 22, 2010 | 01:49 PM
bigboy3l's Avatar
Choosing the plugs is easy. Replacing the ones towards the firewall sucks.
I used stockers as well.
Old Jul 22, 2010 | 02:58 PM
Hawkins04's Avatar
stupid question do you have to change the coils when you change plugs?
Old Jul 22, 2010 | 03:52 PM
Mgpeagle's Avatar
No, no need to change coils.
-Mike
Old Jul 22, 2010 | 03:56 PM
Hawkins04's Avatar
when do you even need to change them then?
Old Jul 22, 2010 | 04:03 PM
Mgpeagle's Avatar
If they go bad or you want to upgrade them. The factory coils should last at least 100,000 - 150,000 miles or more.
-Mike
Old Jul 22, 2010 | 04:08 PM
Hawkins04's Avatar
ok just wondering i have to change plugs on my car soon im going with the stockers since they will work for me
Old Jul 22, 2010 | 05:10 PM
Count of Monte Carlo's Avatar
I changed mine at about 73k as I noticed the idle was not the same. I used Stock P/N- ACD 41-985/ GM 12609877 superceeded from ACD 41-985/ GM12571164 plugs and Taylor Street Thunder 8mm Wires P/N-53005; the wires were about $30-$40 from SUMMIT RACING? I measured the resistance on the 8mm Taylor wires compared to 7mm stock, with no surprise the Taylor Wires had quite a bit less resistance... All this despite being slightly longer that stock as they are for the LS1. In any event I have some pics to show to compare the DOD located to NON DOD located plugs. On the DOD plugs the gap was good but they had deposits. The engine idles smooth again and all the other good things that goes into a tune up. With the DOD I was pretty sure I would not make to 100K before a tune up, at least to my tastes. With the minor things I have done to the engine with an alignment with 77k now, at 70 mph on 90 Thruway I'll get 27.5mpg from Albany to Utica; just touching EPA specs.
Pic 1- DOD plug is on the bottom.
Pic 2- DOD plug on left.
