My dyno results are in.
Only strange thing is the power comes at 6500-6800rpms and at about 6000rpms there is a weird burp in the power band where i lose about 50hp than it comes right back. I dont know if there is a restriction in the tb or what.
id check your tune..especially your ve tables ..i would think maybe a cell was missed in that range causing the weird drop.
That dip - were you running a log during the dyno session? Wondering if you had some knock that dumped your timing for a sec...
-Mike
I will post my dyno chart tomorrow
Golen engine and comp cams speced it out. And my power band is about the same it just shifted up about 500rpms. Compression seems to be lost a little bit. but not a lot.
That kind of torque out of a 5.3 sounds very promising for 350-400 whp depending on how restrictive your intake setup is.
