LS4 compression test results
Old Sep 26, 2010 | 12:37 PM
fieroguru's Avatar
Default LS4 compression test results
My 18K mile LS4 has been sitting for a while (year or more) and I wanted to do a compression check before the cam swap and then again after it to see how much dynamic compression I lose with the cam swap.
Initial compression results were:
1: 220......2: 190
3: 190......4: 220
5: 190......6: 205
7: 200......8: 190
The thing I find interesting is the DoD cylinders are higher... probably from more oil collected in the rings.
Old Sep 26, 2010 | 08:34 PM
AlabamaGuy's Avatar
I'm interested in the afters!
Old Sep 26, 2010 | 08:54 PM
DavidGXP's Avatar
Screw DOD!
Old Sep 26, 2010 | 08:56 PM
AlabamaGuy's Avatar
Originally Posted by DavidGXP
Screw DOD!
Just because DoD screwed you...
Old Sep 27, 2010 | 02:46 AM
blakss's Avatar
lmao
Old Sep 27, 2010 | 07:42 AM
94ss06gxp's Avatar
AHHHHHHHHHHHHH
Old Sep 27, 2010 | 10:46 AM
DavidGXP's Avatar
Old Oct 17, 2010 | 08:07 PM
fieroguru's Avatar
I got the new cam all degreed in where I wanted it, then stripped out the bolts from a friends spring compressor tool after swapping the springs on 3 cylinders. Ordered new bolts and should be able to finish the spring swap this week and get the after compression #'s.
