Transmision Slip Help
Old Oct 1, 2010 | 10:04 PM
AlabamaGuy's Avatar
Exclamation Transmision Slip Help
This happened tonight. I did one pull through 2nd into 3rd without issue. Slowed down and tried it again, when it went into 3rd the RPMs fell off slowly and it hoovered at 4k before picking back up again. About a mile down the road the CEL came on. I waited a few miles and decided to try it again. It did the same thing but for longer, this time I came out of the throttle.
Has anyone else here seen transmission slip cause a CEL? It's fine everywhere but shifting at WOT. SHifts are still firm and snappy everywhere else.
Old Oct 1, 2010 | 11:29 PM
CalamitySS's Avatar
I have a weird problem with mine. If I get on it doesn't have to be wide open it will take off but doesn't feel like all the power is there, but when it shifts to second the tires chirp and then takes off. I honestly don't get on it much and it has happened twice. I have 50K on the trans now. No I do not get a CEL.
Old Oct 1, 2010 | 11:31 PM
CenTexSS's Avatar
Pull the codes and see what'cha got.
Old Oct 2, 2010 | 07:59 AM
94ss06gxp's Avatar
Dave@tripleedgeperformance.com
Old Oct 2, 2010 | 11:36 AM
AlabamaGuy's Avatar
Code was for Rich Bank 1.
Going to put some new fluid in it tonight and see if it helps at all.
Old Oct 2, 2010 | 04:48 PM
1BAD06MCSS's Avatar
3.29's and a TEP tranny is in your future.....
Old Oct 2, 2010 | 05:19 PM
AlabamaGuy's Avatar
PM me and I'll give you my paypal address.
Old Oct 3, 2010 | 01:33 AM
AlabamaGuy's Avatar
Changed the fluid, filter, and put the transgo springs/spacers in there. No slip right now. The old fluid had over 57000 miles on it, looked like my oil when I change it.
Old Oct 3, 2010 | 09:42 AM
1BAD06MCSS's Avatar
LOL! I will get right on that....
Old Oct 5, 2010 | 09:21 AM
leclair87_06monteSS's Avatar
very very simmilar to problem's I had, but mine did not throw a code. Nearing the end of it's life, it would only shift nice when giving it a ton of throttle, shifting under low RPM's was a struggle, and hurt me inside lol
Old Oct 5, 2010 | 06:25 PM
LS1 Racing's Avatar
Are we in denial here, Travis?
Old Dec 2, 2010 | 08:22 AM
06MonteSS's Avatar
LS1Tech Sponsor
sounds like the same issue I started having this morning with mine...
uugghhh...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
