Fvck this car!!!!
it sounds like a plan, but i dont want to do that and it still not work. i put it in drive and it wont go anywhere. it goes to high rpms around 6k. i drop it into one and 2 and it drives but 3 and D its a no go
You're right. I didnt do my research and i told you guys that from the jump. Had i did my research i most definitely wouldnt of purchased this car. The main reason being is because of all the transmission problems i was hearing about when i got to this forum. If i would of known that i wouldnt of got it point blank
Good advise below...the trans has a filter that needs to be replaced...just drop the pan and change the fluid/filter yourself if you want to go that route.
Why spend even more money on something that is proven to be detrimental to these transmissions?!
OP: Since you're in a serious bind and cannot wait on the good things coming, I suggest that you purchase what AlabamaGuy suggested.
