Fvck this car!!!!
Old Oct 29, 2010 | 01:14 PM
  #61
SSCoop's Avatar
Originally Posted by RickAKATed10
Yes please.
And man, does that suck. I'm sorry you're having these issues. It worries me.
It's all good brother. It just goes to show you how much GM cares.
Old Oct 29, 2010 | 03:45 PM
  #62
TheMonteMan's Avatar
are you months or miles out of warranty? im suprised they wouldnt try and sell you on the extended now. have you thought about looking into one of those 3rd party warranties?
Old Oct 30, 2010 | 03:12 PM
  #63
Z28 Autobot's Avatar
and if you build it for 1500..then it should not blow if he does it right. 1500 is cheap for a build
Old Oct 31, 2010 | 01:56 AM
  #64
SSCoop's Avatar
I was surprised as well believe me. i just hit 60k miles on that sunday going to my football game so i was highly upset about that. i was looking at the AAA aftermarket warranty. they cover everything pretty much.
Old Oct 31, 2010 | 02:00 AM
  #65
SSCoop's Avatar
i dont judge his work. he does very very good work i've known him for years. and yes it is cheap for a build
Old Oct 31, 2010 | 03:38 PM
  #66
Count of Monte Carlo's Avatar
Originally Posted by SSCoop
it sounds like a plan, but i dont want to do that and it still not work. i put it in drive and it wont go anywhere. it goes to high rpms around 6k. i drop it into one and 2 and it drives but 3 and D its a no go
I'm thinking the forward servo/ servo circuit is blowing by. Could be a cracked piston. Do you have reverse?
Old Oct 31, 2010 | 10:28 PM
  #67
SSCoop's Avatar
yeah reverse works just fine. gears 1 and 2 work but 3 and D dont work at all.
Old Oct 31, 2010 | 10:45 PM
  #68
4THGENCAMAROFAN's Avatar
Originally Posted by crazyjoe
Definitely sucks to hear. I'm waiting on mine to crap out, only so I can have an excuse to build the tranny up. I'm sure when it goes I'll be pissed too, hopefully not to the point of getting rid of it though. What are your plans, fix it and sell it or fix it and keep on modding? Just curious.
Sexy car....because of the sexy paint. lol
Man i'd be pissed if my tranny went out, but like you said gives you an excuse to build it up.
Old Oct 31, 2010 | 11:09 PM
  #69
itsslow98's Avatar
Ahh how i dont miss factory auto trannies lol. Build it right this time and you shouldnt ever have to worry about it again.
Old Nov 1, 2010 | 10:00 AM
  #70
If you manually up shifted it, you should have 3rd and 4th. If the forward servo/ forward one way clutch were bad you would not be able to accelerate from a stop in with the selector in Drive and Overdrive. If you try what I said initially, you would have localized the problem. It is repairable providing you can gain acess to the rear of the transmission.
Old Nov 1, 2010 | 01:00 PM
  #71
LS1 Racing's Avatar
Sounds like a bad forward apply band to me. This is the classic symptom.
Unfortunately, fixing that requires a complete teardown, and there's no easy way to get to it without taking the whole tranny apart.
Old Nov 1, 2010 | 01:30 PM
  #72
If it is the Forward Band then you would need to open the case remove all the parts. If its the servo then the engine would have to be supported and the rear of the frame lowered to gain access to the servo cover which is held by 3 bolts. In my experiances, I've seen more servos fail. I cannot say I have seen a band fail but I guess theres a first time for everything. To check out the servo, you would need two jack stands, a jack and or transmission floor jack, hand tools, and a couple of hours.
Old Nov 1, 2010 | 01:48 PM
  #73
LS1 Racing's Avatar
If it is the Forward Band then you would need to open the case remove all the parts... In my experiances, I've seen more servos fail. I cannot say I have seen a band fail but I guess theres a first time for everything.
According to Dave at TEP, it's pretty common.
Old Nov 1, 2010 | 02:41 PM
  #74
SSCoop's Avatar
yeah my mechanic said that its common. he had worked on a LS4 GXP not too long ago that had the similar problem
Old Nov 1, 2010 | 03:02 PM
  #75
Well thats no good... at least you can still drive it.
Old Nov 1, 2010 | 03:05 PM
  #76
SSCoop's Avatar
na i cant drive it. this thing wont go anywhere
Old Nov 1, 2010 | 04:21 PM
  #77
I thought you said you had manual 1st, 2nd and reverse?
Old Nov 2, 2010 | 10:45 AM
  #78
SSCoop's Avatar
I do have manual 1 and 2 but i dont want to drive it and have anything else happen to it.
