e85
Old Dec 4, 2010 | 02:08 PM
LS1 Racing's Avatar
Originally Posted by JDMC5
I'm sorry I don't know what you mean by a lambda sensor? Is it like an alcohol sensor? I would assume by the name it would sense stoich for what ever fuel you are running.
Close...Senses ethanol contact in the fuel. It mounts inline to the fuel line before it even reaches the injectors.
Old Dec 5, 2010 | 11:48 PM
JDMC5's Avatar
ok, yeah also refered to as an alcohol sensor.
Old Dec 6, 2010 | 12:08 AM
heavyft's Avatar
When e-85 is cheap I run a 60/40 87gas/e85 mix. I calculate it to be about 95 octane. The monte really opens up and runs smooth. Plus the smell is addictive. I only have a longer/slow start on really cold mornings but it is easily fixed by adding more gas. When I run higher than 60% e85 the traction control goes off at 100% it throws a bank 2 lean code. I have ran this mix for the last 20,000 miles 38,000 total. I do notice more power and my mpg stay right around 22-23.
Old Dec 6, 2010 | 12:15 AM
LS1 Racing's Avatar
Yeah, I just call it by it's actual name. Didn't mean to show you up.
Old Dec 6, 2010 | 12:19 AM
LS1 Racing's Avatar
You're really rolling the dice with those concentrations of ethanol. There's a reason that E10 is the most that you can get in normal gasoline, as higher concentrations will eventually damage the fuel lines and fittings in a non-flexfuel car.
Old Dec 6, 2010 | 11:12 AM
JDMC5's Avatar
Thats fine, I was merely trying to understand.
Not just that but he's now running incredibly lean. Stoich for that mixture is somewhere around 12.7 but his computer is thinking 14.7 is stoich. That's a full 2 points lean. A word of advice heavyft, stop doing that unless you want a new engine sometime in the future.
Old Dec 6, 2010 | 05:42 PM
Brian396's Avatar
Are you 100% on that? Every thing I read about it said that any car that was designed to run e10 had the coatings to protected it for e85.
Old Dec 6, 2010 | 05:58 PM
LS1 Racing's Avatar
With a 10% ethanol content, you don't need any protection. That's why it's in regular pump gas and can be run through much older vehicles.
Old Dec 6, 2010 | 07:39 PM
Brian396's Avatar
This is copied off Wikipedia-
Corrosion
E85 can cause damage, since prolonged exposure to high concentrations of ethanol may corrode metal and rubber parts in older engines (pre-1985) designed primarily for gasoline. The hydroxyl group on the ethanol molecule is an extremely weak acid, but it can enhance corrosion for some natural materials. For post-1985 fuel-injected engines, all the components are already designed to accommodate E10 (10% ethanol) blends through the elimination of exposed magnesium and aluminum metals and natural rubber and cork gasketed parts. Hence, there is a greater degree of flexibility in just how much more ethanol may be added without causing ethanol-induced damage, varying by automobile manufacturer. Anhydrous ethanol in the absence of direct exposure to alkali metals and bases is non-corrosive; it is only when water is mixed with the ethanol that the mixture becomes corrosive to some metals. Hence, there is no appreciable difference in the corrosive properties between E10 and a 50:50 blend of E10 gasoline and E85 (47.5% ethanol), provided there is no water present, and the engine was designed to accommodate E10. Nonetheless, operation with more than 10% ethanol has never been recommended by car manufacturers in non-FFVs. Operation on up to 20% ethanol is generally considered safe for all post-1988 cars and trucks.
I read it on the internet so it has to be true. Lol
But seriously I’ve got a couple of friends that converted over to e85 a couple of years back with little more that a tune with no issues.
Old Dec 6, 2010 | 09:33 PM
LS1 Racing's Avatar
Corrosion
Interesting stuff!
Still, I would like to know if GM uses different fuel lines and fittings in the Flexfuel equipped vehicles.
Thanks for posting that!
Old Dec 7, 2010 | 01:33 PM
JDMC5's Avatar
97-03 grand prix's were definitely not designed with E85 in mind but guys convert all the time with no issues in regards to corrosion.
Old Dec 7, 2010 | 01:43 PM
  #32
Hawkins04's Avatar
stupid question but is there a reason other than it being cheaper to run?
Old Dec 7, 2010 | 02:12 PM
  #33
TheMonteMan's Avatar
isnt e85 a higher octane?
Old Dec 7, 2010 | 06:49 PM
  #34
Brian396's Avatar
E85 is 105ish octane. With the turbo and E85 its defiantly makes more power, and my tune is way off. With a n/a car I’ve heard you may make a little more, but gas mileage is going down. I went from 17 mpg to 13 mpg. (but the tune is off and I’m not driving it on the highway as much) So if E85 ain’t significantly cheaper I would waist your time.
Old Dec 7, 2010 | 07:11 PM
  #35
1CL3ANSUP3RSPORT's Avatar
So maybe a stupid question but Racing fuel is E85?The reason I ask,is there a place near by that sell I think 101 oct.On thrusday I planned on doing a mixture of 91 and 101 1/4 (101) & 3/4 (91).I've been asking around but no solid answer,any help?
Old Dec 8, 2010 | 09:52 AM
  #36
adryan16's Avatar
Well, it depends on what you're racing, in regards to racing fuel. But if my assumptions are correct, no racing fuel and E85 are totally different things, for the short of it.
