4T65E-HD Delayed engagement fix
The Super's transmission shifts very smooth from the factory, almost unnoticeable. From what I've read, to achieve a smooth shift the line pressure is reduced. Sometimes a waveplate just isn't enough to cushion the engagement of a clutchpack. Naturally I wanted to check the line pressure in my trans so I can continue onto pinpoint diagnosis. First I checked the line pressure with the Tech 2 at work.
Minimum line pressure in P R N is 79-101 psi. The scan tool will show this value in amps. 1.0 amp is the spec for minimum line pressure in all gears. D4 D3 D2 line pressure is 74-86. D1 is 146-187. If you have the opportunity, you should take the Tech 2 with you on a test drive and try to duplicate the problem. I didn't have time so I just recorded D1 line pressure @ .78amp at 93*F. I really should have taken it out on a test run to watch the values through all the gears once the transmission was warmed up. But you'll see later on why I didn't need to.
If you don't have a Tech 2 or access to one, there is a pressure test port on the case of the 4T65. On v6 cars its easily accessible. On v8 equipped cars, the exhaust pipe that crosses over the trans blocks it almost entirely. You could probably get the plug out, but there isn't enough clearance to thread a pressure gauge fitting in.
I continued to dig and found several TSb's. The TSB that best fit my problem is bulletin no: 08-07-30-040B. The summary is that a new transmission pan magnet was released because the old magnet can become "saturated" with metal shavings. Once "saturated" it can no longer collect metal shavings and the shavings go to the PCS solenoid. The solenoid is magnetic and thus will collect the shavings, this throws off the readings and decreases line pressure. "When checking PCS line pressure and it shows that the line pressure is lower than required for a given current at the PCS or the transmission oil pan was removed, only then should the transmission oil pan magnet be upgraded."
My Super has 71K miles on it and I planned to do a transmission service anyway so this worked out. I called up the local Chevrolet dealer and ordered eight (8) quarts of Dexron VI and a filter. I talked to a service writer about my issue and asked if I did the work will GM still send me the new magnet free of charge. The dealer was more than helpful and ordered the magnet free of charge aswell. For reference here are the part numbers and price.
Filter kit #24227477 $32.23
Dexron VI #88861003 $6.47 (each)
Magnet #29535617
Start by dropping the pan, I removed all but a 2-3 bolts towards the front of the pan. It wasn't really messy but it will take a couple minutes to drain out of the pan. After dropping the pan I inspected it for burnt fluid, clutch material, how much metal is on the magnet, etc. The fluid was burnt and the magnet had an average amount of metal on it. After a quick trip to the parts washer I was ready for reassembly. For the 4T65 the TSB will have you keep the original magnet in it's "corner", behind the raised portion of the pan. The second magnet is installed on the new filter assembly. See photo for location. The gasket is reusable, just rinse and dry. Pan bolts torque is 13 ft lbs. Refill with Dexron VI, mine took just over seven quarts. I used GM Dexron VI. Its been over a month and 1,700 miles without any slipping.
Just a heads up, the dealer won't perform this TSB under warranty unless you request a transmission service where the pan gets dropped. The TSB was very adamant about this. The magnet should only be replaced if the pan is being dropped under normal maintenance or diagnosis of a customer concern requires it.
Hope this helps someone else out. I'm by no means an expert but stuff like this interests me alot.
I drop my pan once a summer and change the fluid and clean the magnet/pan and inspect what I can.
Couldn't hurt to install 2?
As I mentioned in the earlier post, the trans needs to come out to get to it, according to Dave @ TEP.
there are really no simple fixes other than a fluid change, and hoping for the best ? because when i checked my fluid levels the other day after i got my first revvv....clunk ... it was a little darker than normal ... at 55K miles and ive had the car since 35K
man this winter is gonna kill my car ... i really need to find something else to drive and park her til it gets warm
With more than 30 years experience, never had problems with a complete flush, if it is done correct and with a clean machine.
The WYNN`s kit for flush and conditioning is a must! Be sure they follow the instructions and theres enough gas in the car to complete it.
You may start to notice the torque converter locking and unlocking while cruising. Or, you might see the rev-and-clunk when trying to pull away from a stop.
Sucks, but it's only a matter of time.
No other shifting problems. And so far, I have not had TCC lock and unlock happening.
The other thing is, my "slip then catch" happens very sporadically. I drove a lot of miles on Sat, Sun, Mon, and 40 miles so far today. Sat was bad, happened numerous times. Sunday and Monday and so far today, not once. Similar load, driving, and temperatures outside.
I did my first pan and filter drop at 50,000 miles (Dex VI - this is a 2007 Buick Rendezvous), then again at 75,000, and about to hit the 100,000 mark at which point I was going to do one.
The problem started years ago at around 65,000 miles. So 30,000 miles ago.
It's kind of rare but annoying and definitely worries me.
I tried one bottle of Lubeguard Red, didn't make any difference.
Are line pressures the root problem? If so, would a trans tune to keep pressure at idle around 120psi be all I need perhaps?
Thanks.
Brian
