Dyno Results LS6 intake etc
#61
There are several ways to do the swap, depending on your preferences and means. Only thing I would do different is buy Brian396s adapter, which was not offered when I did my swap.
Like CenTex was saying, dynos are only good for relative comparisons unless they are the super expensive and regularly calibrated dynos the OEMs use. Hot Rod just had an article on this in the latest issue. iirc, they saw anywhere from 550 to 660 WHP on the same car at different dynos, and something like +/- 20 WHP on the same dyno from run to run.
Frankly, a dyno is just a tuning tool. The amount of variability in engine performance and how it is measured is staggering if you really look at it.
#62
When I get my headers installed and new exhaust, I will have them re-tune it and give me the most pessimistic results possible...LOL And do it in 3rd gear!
#64
you guys i got a question. from my understanding the DOD connector clears with the LS1 intake but the OPS doesn't so the OPS gots to be modded(put at an angle) and the DOD just needs to be extended correct? i seen a couple of you guys redo the whole DOD connector but is there a reason why its just not cut with slack and extended with same gauge wire and soldered back?
#65
The LS4 intake manifold snout is angled up to provide clearance. Extending the DoD/AFM connector provides that clearance because heatshrinked wires take up little-to-no real estate versus a 0.25-0.5" (?) male plastic connector.
fieroguru's DoD/AFM VLOM with an LS2 intake manifold (FYI: LS2 intake won't clear the OPSU and DoD/AFM connector without modification to the intake due to its shorter and lower throttle body inlet):
![](http://i54.tinypic.com/2ymdb1t.jpg)
(I rotated the following picture by 180°)
![](http://i54.tinypic.com/28ls2vn.jpg)
![](https://i152.photobucket.com/albums/s162/fieroguru/LS4/IMG_7413.jpg)
![](https://i152.photobucket.com/albums/s162/fieroguru/LS4/IMG_7414.jpg)
![](https://i152.photobucket.com/albums/s162/fieroguru/LS4/IMG_7415.jpg)
![](https://i152.photobucket.com/albums/s162/fieroguru/LS4/IMG_7416.jpg)
![](https://i152.photobucket.com/albums/s162/fieroguru/LS4/IMG_7417.jpg)
![](https://i152.photobucket.com/albums/s162/fieroguru/LS4/IMG_7418.jpg)
![](https://i152.photobucket.com/albums/s162/fieroguru/LS4/IMG_7421.jpg)
![](https://i152.photobucket.com/albums/s162/fieroguru/LS4/IMG_7422.jpg)
![](https://i152.photobucket.com/albums/s162/fieroguru/LS4/IMG_7428.jpg)
LS6 and LS1 bottoms versus LS2 bottom (image rotated 90° to the left):
![](http://i52.tinypic.com/290x3t2.jpg)
![](http://i51.tinypic.com/2s9r9ky.jpg)
If you do happen to ditch DoD/AFM, you can use the LS2 VLOM (and intake) and angle the OPSU without having to cut into the intake manifold.
Third to last sentence on the page:
http://www.fieroaddiction.com/LS4/engine.html
#67
Very true. I forgot about that!
Here's some pictures of the LS1 mounted to the LS4 VLOM (step-by-step):
http://www.fiero.nl/forum/Forum1/HTML/062546-3.html#p85
It explains and shows the OPSU and DoD/AFM connector issues.
