Another intake option?
Old May 9, 2012 | 08:08 AM
Brian396's Avatar
Pt# on tb RME87-3C9992
I think all of the 09-10 Silverado TB are the same.
Originally Posted by x11 nut
Why did you scrap the intake, was it not worth using/selling?
Not worth the hassle, my modified power steering pump is leaking from the weld, I would have to redo the wiring harness on the front of the motor, and cut and modify the hood bracing.
I sold the intake but I still have the tb and and plug end (you would have to remove LS4 tb plug and repin) for sale $125 shipped.
I think the best bang for the buck on an intake swap would be a LS2 intake with this tb.
Old May 10, 2012 | 08:49 PM
DavidGXP's Avatar
Tpis ls6 with the 90mm ls2 flange.
I keep telling everyone this... Ls6 out preforms the ls2.
Stock injectors can be used with fic
Adapters/spacers, which enables stock pigtails.
Old May 21, 2012 | 07:57 AM
Brian396's Avatar
I'm wrong I thought the LS2 intakes was selling for $50, but it's closer to $200.
I thought everyone already knew the LS6 was the best.
Old May 22, 2012 | 07:43 PM
ImpSS07's Avatar
Brian, Does this TB's(below) bolt pattern match the one on the adapter you made for me?
[QUOTE=Brian396;15618470]
Old May 23, 2012 | 07:51 AM
Brian396's Avatar
No, that's the 90mm it's got a bigger bolt pattern.
Old May 23, 2012 | 01:50 PM
DavidGXP's Avatar
How about some more pics of that truck in the back ground?
Old May 23, 2012 | 07:45 PM
ImpSS07's Avatar
Well ****.
Thanks!
Old May 24, 2012 | 08:23 AM
Brian396's Avatar
She's a lil ruff but defenetly an improvement over old blue. I'm diggin the 3 on the tree but the straight 6 has a bit to be desired.
Old May 25, 2012 | 07:07 PM
DavidGXP's Avatar
Its got potential!
Would be a great overhaulin project
Old May 26, 2012 | 12:06 PM
indynotch50's Avatar
Will the ls7 / ls3 work?
Old May 26, 2012 | 04:54 PM
Brian396's Avatar
Nope. Diffrent intake runners.
Old Oct 29, 2012 | 12:16 PM
  #32
DavidGXP's Avatar
Back from the dead
You were so close!
The wiring harness was too short?
Old Oct 29, 2012 | 12:29 PM
  #33
Brian396's Avatar
For some odd reason I've been looking into toyota mr2 electric power steering pumps. When I got my trans built Dave replaced my motor mount that was messed up for awhile. So idk if there is clearance for the TBSS intake, so maybe the regular truck intake? And the fast intakes? But idk what I'm doing? I picked up my GMC a couple months back, and I want to set it up do do a couple of truck pulls next year. And I just picked up a 88 GTA off a friend that I want to set up for road courses. So the GXP maybe on the back burner for awhile?
Old Jun 11, 2013 | 06:56 PM
  #34
x11 nut's Avatar
Back from the dead - about how much clearance is needed for the hood? Just thinking the 3800SC guys use cradle spacers to fit large intercoolers under the blower..
Old Jun 14, 2013 | 04:41 PM
  #35
Brian396's Avatar
It was close, just needed to modify the brace. But like I said idk if the bad motor mount made the engine sit lower?
Old Jun 14, 2013 | 06:02 PM
  #36
91parkave's Avatar
Moderator
Absolutely. IMO though The ls2 intake trumps the work involved and performance.
