Another intake option?
Old Feb 11, 2011 | 09:02 PM
Brian396's Avatar
Default Another intake option?
I ordered a TBSS intake today. Just thought you guys might be interested.
https://ls1tech.com/forums/parts-cla...-iii-tbss.html
Old Feb 11, 2011 | 09:03 PM
Battle_Ravage's Avatar
Aren't they restricted, too, but not near as bad as ours?
Old Feb 12, 2011 | 11:55 AM
Brian396's Avatar
It’s suppose to be better than the LS1. I cant find any dyno numbers on that thou. I did find:
LS1 vs. fast +20 hp http://www.s10forum.com/forum/f213/l...umbers-398693/
Truck vs. fast +34hp http://www.superchevy.com/technical/...ake/index.html
Truck vs. TBSS +15hp http://www.performancetrucks.net/for...d.php?t=455536
These are not the same engine be any means but, should make as much hp as the LS1 with more torque. In any case it should be a ton better than what we got now.
Originally Posted by neilownz
I would say no. The back might push to the power steering area and it's meant for square port heads?
Hmm that must be another truck intake that's square port.
Its cathedral port. But yeah the it might not fit, hell the hood might not close? That is one big ugly SOB.
Old Feb 12, 2011 | 12:22 PM
Good to know.
Old Apr 2, 2011 | 07:53 PM
Brian396's Avatar
No go.
I modified the alternator bracket, but now its hitting the power steering line. I may modify the power steering pump? IDK? I think I’ll wire up the TB 1st and see if I can get that working. Oh the wiring harness needed a little tlc, and the hood liner will need to come off, but that big ugly somabitch actually looks good under the hood. Fills up the engine bay nicely.
Old Apr 3, 2011 | 10:33 AM
blakss's Avatar
Got pics?
Old Apr 3, 2011 | 02:52 PM
Brian396's Avatar
Crap no. I was going to get a pic of both intakes setting next to each other and I was going to get a pic of it under the hood. I got sidetracked with the power steering pump, and put everything together before I grabbed the camera. Next time I’ll try to get a standard truck intake and see if it fits with out modifying the power steering pump. I think with the acceptation of modifying the alternator bracket, the truck intake would be bolt on.
Also I still like thishttp://www.edelbrock.com/automotive_...chevy-ls.shtml
Old Apr 3, 2011 | 03:51 PM
Brian396's Avatar
A little more info on the truck intakes.
http://www.performancetrucks.net/for...d.php?t=392089
Originally Posted by Steve Bryant
It appears to me that at wide open throttle (WOT), the truck/LS6/FAST all better the HP and torque of the LS1 through most of the operating range. Further, it appears that the truck and the LS6 hang right in there with the FAST until around 430 HP and a bit over 5,000 RPM’s. Then the FAST and LS6 begin to ease away from the truck manifold. The LS6 pretty well keeps pace with the FAST manifold for a few hundred RPM's and a few more HP before the FAST manifold eases away from the LS6. HP is directly related to mass air flow and I believe that that is mainly what we are seeing borne out here.
Old Apr 6, 2011 | 07:59 PM
Brian396's Avatar
Hooked up the TB and logged with Hptuners
ETC Position----------TB90-25% 50% 76% 100% / LS4 TB-25% 50% 76% 100%
ETC TPS 1--------TB90-3.43V 2.45V 1.53V 0.59V / LS4 TB-3.51V 2.57V 1.55V 0.59V
ETC TPS 2--------TB90-1.55V 2.53V 3.45V 4.41V / LS4 TB-1.45V 2.37V 3.41V 4.37V
Throttle Position (SAE)-TB90-31% 51% 69% 88% / LS4 TB-30% 49% 69% 88%
Looks good I need to order a 6 pin connector now.
Old Apr 6, 2011 | 08:18 PM
nmp0098's Avatar
I think the truck intake is a good option. It matches really well to turbocharging because it boosts torque before the turbo kicks in and you generally don't rev turbo motors to the moon. Are you going to move the power steering pump (reservoir)?
Old Apr 6, 2011 | 08:31 PM
Brian396's Avatar
The reservoir should be fine. It’s the suction line on the pump its self.
Old Jul 5, 2011 | 05:08 PM
Brian396's Avatar
Update. I modified an O’Reillys power steering pump and put it on today. Looks like the intake might bolt on now. I need to order a pig tail for the TB. Maybe get it bolted on this weekend.
Old Jul 6, 2011 | 12:09 PM
06silverss's Avatar
Thats really interesting. Im looking into swapping out my intake but still don't know which one im going with yet.
Old Jul 6, 2011 | 03:25 PM
AlabamaGuy's Avatar
Interesting. Truck guys see good gains from them
Old Jul 6, 2011 | 04:09 PM
DavidGXP's Avatar
Same pump I am using now. It is very noisy and sounds like a supercharger at low rpm's
I have bleed the system twice and then had the dealership replace the cooler lines and they bleed it. Still noisy.
That intake is going to kick butt down low for what you are doing. I am really exited about that TB.
Old Nov 13, 2011 | 06:41 PM
Brian396's Avatar
Well I got the intake bolted on. Its still hitting the intake tube on the power steering pump. The hood closes but hits on the brace. I’ve ground a lot off the intake but still hits. And the wiring harness is going to need a lot of work. I really cant see anyone else doing this? But TB on a LS6 or the Edelbrock intake would be nice.
Old May 4, 2012 | 10:36 PM
supercatxr7's Avatar
Do you have gm part # for the throttle body?
Old May 5, 2012 | 07:52 AM
Brian396's Avatar
I left it at work, I'll get it Monday. I've heard that its not a good tb for boost, but idk for sure?
I've scraped the intake, so no more updates on this thread.
Old May 7, 2012 | 08:00 AM
Gettin Faster's Avatar
I would also like the part# for the throttle body.
Old May 7, 2012 | 04:28 PM
x11 nut's Avatar
Why did you scrap the intake, was it not worth using/selling?
