CAI intake research
Old Feb 17, 2011 | 05:51 PM
f3racer's Avatar
Default CAI intake research
I have seen some debate online about different intakes for our cars so I decided to do some research. I'm sure its been proven that the stock airbox setup is restricting so we will start with my current setup. Stock airbox removed and spectre filter in place. Stock tubing and MAF. Starting off I took some temp readings. Outside temp and underhood temp were all done with the same thermometer. Crossover pipe is already heat wrapped.
Outside temp. 71 deg
Underhood temp on tubing close to throttle body 195
Temp at filter 112
Temp in fenderwell where proposed filter will be 96.
I am getting together the tubing required to run the CAI. Once completed I will take temps again wrap intake with heat wrap and take readings again.
More to come
Old Feb 17, 2011 | 06:03 PM
LS1 Racing's Avatar
What are you using to measure underhood temps while driving?
Old Feb 17, 2011 | 06:22 PM
DavidGXP's Avatar
I am a big fan of research! Your best bet would be to do some IAT readings with the factory sensor. The stock box keeps things pretty cool. Its just restrictive due to the small *** opening. The filter is pretty free flow due to its size.
I had a cone filter on the end of my MAF and my IAT's were always about 20* hotter then ambient air while driving around. IAT temps would really start to climb when coming to a stop or after letting the car sit parked for awhile. Sometimes my IAT's would soar to
115* on a 42* day after sitting for about 10 mins.
I have the cold air inductions box. I used my cowl weather stripping to seal up the top, side and bottom. I have also wrapped my Intake ducting form the box to my TB with some refelctive laced shielding. My IAT readings are more stable now. The only problem is that a lot of heat comes from the throttle body and since the maf is close to the tb the sensor gets heated up pretty quick when the engine is turned off. The heat from inside of the engine escapes from the tb and out thru the air filter. Heat also comes out of the valve cover clean side breather.
Old Feb 17, 2011 | 06:45 PM
f3racer's Avatar
I have this awesome velcro that I use for mounting my lap timer to my bike tail during races I figure if it can handle 160+mph it can handle driving around in the gxp.
Old Feb 17, 2011 | 06:47 PM
f3racer's Avatar
I'm also thinking of finding somekind of turbo heat shield or something for the throttle body
Old Feb 17, 2011 | 07:51 PM
DavidGXP's Avatar
I made one for the TB before its useless. Make one for the bottom side of your MAF and attach it to the MAF mounting ears.
Old Feb 17, 2011 | 08:28 PM
f3racer's Avatar
Not sure I understand why it would be useless for the tb but not the maf.
Old Feb 17, 2011 | 08:43 PM
DavidGXP's Avatar
Because the the IAT sensor is in the MAF. Heat rises so the heat shield helps to block some of the radiant heat from heating up the MAF housing.
I was talking about internal engine heat exiting the the TB and traveling thru the intake tubing and out through the air filter. When this happens the IAT sensor gets hot. The TB doesn't really get all that hot. Its aluminum so it dissipates the heat rather quickly
Old Feb 17, 2011 | 08:45 PM
f3racer's Avatar
Oh ok. So what is the sensor in the tubing right next to the tb. Vaccum hose maybe?
Old Feb 17, 2011 | 08:48 PM
DavidGXP's Avatar
IAT (Intake air temp) sensor is inside the MAF (Mass air flow) plastic tubing.
Old Feb 17, 2011 | 08:50 PM
DavidGXP's Avatar
The sensor is very... slow.... at picking up changes in intake air temp.
Old Feb 18, 2011 | 08:42 AM
Mgpeagle's Avatar
You can make a heat soak reduction kit for about 50 - 60 dollars buying the parts from Casper's Electronics. That's what I did. It was plug and play too.
-Mike
Old Feb 18, 2011 | 10:42 AM
DavidGXP's Avatar
-Mike
Hey Mike.. I have thought about doing this mod. Seems to me like we would be tricking the computer. The IAT sensor needs to be as close to the intake manifold as possible. Obviously, the sensor would read higher temps so tuning would be required to allow the computer to pull less timing at higer temps.
I would like to adapt a faster reading IAT sensor into our MAF. The stocker reads temps very slow as mentioned above.
The ECM starts to pull timing at 95* right?
Old Feb 18, 2011 | 11:24 AM
Mgpeagle's Avatar
I think it is around that temp for the timing to be pulled. I only use my HSRK from spring to early winter. Once it gets 30 degress or below I plug back in the stock one. The HSRK is only going to give us about 2* additional timing anyway. I notice I go through a little more gas with it plugged in. Mine is located in the GXP driverside lower fenderwell.
I went with these: Note, our cars have the larger plug for the MAF like the G8's do.
http://www.casperselectronics.com/st...oducts_id=1137
http://www.casperselectronics.com/st...roducts_id=964
http://www.casperselectronics.com/st...oducts_id=1174
The parts were less expensive when I did mine. (Almost 1.5 years ago...) it is still cheaper than the Vector Motorsports one for 100.00.
-Mike
Old Feb 18, 2011 | 07:21 PM
f3racer's Avatar
well here is the mock up for the CAI tubing. only 2 bends and an extra 24" if piping, but a 100 deg (estimated) difference between the tb and the filter and around 20 degrees difference between the old filter location and the new. if i heat wrap the tubing it "should" keep temps nice and cool all the way into the tb. i know that i have seen a million people saying that the extra lenth in tubing robs power but so does the huge amount of heat being drawn in from under the hood. the location of the filter will not be about 5 - 6 inches above the bottom of the bumper. also right behind the brake cooling intake hole in the front bumper.
excuse my crude microsoft paint skills
Old Feb 18, 2011 | 08:34 PM
DavidGXP's Avatar
Looks good too me.
Old Feb 26, 2011 | 01:40 AM
DavidGXP's Avatar
Updates?
Old Feb 26, 2011 | 05:49 PM
f3racer's Avatar
nothing yet. i have the tubing but finding the right pieces of silicone hose to hold each piece of pvc together i becoming a pain.
Old Feb 26, 2011 | 06:04 PM
06MonteSS's Avatar
LS1Tech Sponsor
http://siliconeintakes.com/
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
