Intake swap guys, wheres the MAP sensor go??
Just like the title states, what do we do with MAP sensor??? If someone can post a link or shed some advice id appreciate it, im on my phone right now and im not having any luck with the search (ls1 swap btw).
Joe.
Joe.
I mounted mine on the rear of the manifold by drilling an appropriate hole in the manifold. It just fits with the LS6 mani. I don't know how the others did it.
EDIT: You are going to want to mock it up with the connector on it to find a good mounting location.
Thanks fellas, just wanted to make sure it could go basically anywhere in the intake. All I need to do now is find someone who can weld aluminum (opsu) and we'll be done.
By the way, if you haven't already cut the OPSU I found that a 30* angle works perfectly.
I figure we'll place it behind the tb (my "anywhere" comment was kind of vague, lol). Thanks for the hole size and angle info fellas, greatly appreciated!
