LS1/LS2/LS6 intake swap Sticky!!!
#103
I'm a little late, but this is the best thread ever period. Thanks to Dave and anyone else involved! Dom you stuff is looking good too!
Question, wouldn't the best thing to do for a throttle body, for making more power, be to convert to a cable style? Pedal assemblies can be had at a junk yard cheap, and the throttle bodies themselves are cheaper especially if you want something giant to support big power. And the tuning for that is simple.
Also, those stock LS6 injectors, how much power are they good for? And any ideas on prettier fuel rails that fit?
#104
The LS6 injectors are good for 450+ crank HP on our engine. There are LS6 Vettes pushing over 400 whp running stock injectors.
FIC sells adapters that will allow the use of the LS4 mini injectors for use with a LS6 rail, and intake. The adapters fit over the tops of the stock injectors and uses thicker lower O-rings. New LS6 injectors can be bought for less then 150.00. You would still need to use the LS6 style rail with either injector.
#105
Converting to a cable operated TB is no easy task and would cost a small fortune. You would need a ECM, pedal, cable, TB, and serious tuning. I also think the crank sensor would need to be changed too in order to use the older style ECM.
I need a new E67 ECM to make the trans work as well. Then I save money on the TB vs getting a stock 90mm and having it ported. But IDK just tossing around options. I really want to run some billet fuel rails to dress it up a bit. My best friend is a dyno tuner too, so I want to give him a challenge anyways
#106
Keep you stock ecm and send the ls6 intake off to t.p.i.s and have them plastic Weld a ls2 90mm inlet. Then use the ls2 tb and maf. (bolt-on)
You will need to modify the DT headers, crossover pipe in order to gain clearence. Make sure you use the bellhousing adapter. The block will be pushed towards the presenger fenderwell about 1/8-1/4 of an inch. You'll have room, as long the engine gets installed from underneath.
#107
I would keep my stock ECU if it would work with the 6T75
also, i wont need the adapter plate, i could use a spacer i guess if i really need the clearance
#108
well i got a little more headway toward doing the swap. i bought a brand new GM alt bracket and cut it up on a band saw today. Im gonna smooth out the edges and send it out for powder coating soon. i had a buddy cut and weld the new position for the OPSU. did it a little different than stated here. i like the location of how this is done, just hope it all works out in the long run. wont know till its on the car. BTW im gonna sand the OPSU area down a little and shoot the whole thing with black paint because dirty aluminum is ugly.
#109
question i have for whoever would know. there are plastic inserts in the valley tray at each hole where the bolts go through. I am missing like 5 or 6 of these inserts, as you can see the 2 by the OPSU port are gone, and need to know what these were for? are they a cheap retainer so you dont need loose the bolts, or are they for something else? and lastly, do i need them? i woudlnt think so, but would like to know so before committing to putting this on.
#110
Couple steps forward tonight. I sanded the intake down with an angle die grinder and washed it the whole thing down with hit water then some brake clean to get all the old gummed up stuff out. Tore the old MAP sensor bracket out as well. I also boxed up my alternator bracket and its going put to powder coat tomorrow. So I need to plug the back and possibly trim around the throttle bracing area on the intake. Its a tight fit to where the OPSU is welded and the neck of the intake and don't want problems last minute when installing it. And plug the old vacuum port on the neck area as well.
#114
Not much to report, but I got the alt bracket back from.the powder coater and it looks awesome. Can't even tell where I cut it up. That little bit of work smoothing it all out made it look a lot nicer.
#116
Question regarding fast intake... does the "hump" u discussed only make contact with the power steering tank? I'm thinking of just making longer lines and relocating the radiator support. In order to utilize a fast intake
#117
any updates on this?
Also, I was wondering if instead of replacing the vacuum port on the back of the intake with a freeze plug why not make a piece that can go in its place, use the stock oring & fit the map in it. This is a better spot for the the map instead of near the tb.
#118
longer lines and a PS Res relocation would be the best was to go about making the additional room required. side effect of possibly running it a few degrees cooler as well not being right up on the engine like that.
#119
as far as i can tell that is the only major issue. im STILL waiting on my buddy that has a FAST intake to let me poke around and see what all needs done. there's a couple nipples that look to also need trimmed off and sealed with epoxy back there too.
I don't think that anyone on here (including myself) has enough supporting mods to benifit the FAST
#120
Only one issue with that is i'm currently in a guns/ammo/reloading/etc buying spree just incase SHTF soon. i'm well up over a cam swap and close to a CarTuning turbo kit in total spent in 2 months.
