60 ft tricks
1st run
no burnout, using tapshift.
60 ft was a 2.4
1/4 was 14.58 at 97
2nd run
burnout, tapshift
60 ft was 2.4
1/4 was 14.50 at 97
3rd run
burnout, car in drive
60 ft was 2.2
1/4 was 14.50 at 95
i think the consistant times prove that the cai is keeping the air cold but i think it might be restricting it some how as well. i couldnt keep the front end from spinning and my burnouts with the t/c off still felt like it was kicking in somehow. the car was falling on its nose when i launched the car and got wheelspin.
If you have t/c off but you feel like it's still kicking on it's probably the anti-score kicking in.
I find that loading up the torque converter to 2200 rpm and then easing into the throttle works best. I don't get to full throttle for 2 to 2.5 seconds and still have a bit of wheel spin at times.
Once you figure it out, 60's of 2.1 are achievable. Some do better, some do worse - but it depends on track conditions.
Edit: beat me to it
Drive around the water box, stop, floor it, let her spin, then stage. 2000 was the sweet spot for me back then, then half throttle and a slow roll to the floor. I was cutting 2.0x short times on stock tires @ around 23 psi.
http://www.zzperformance.com/grand_p...les1.php?id=21
How to Achieve Neck Snapping 60' Launches
How to achieve neck snapping 60 foots
There are many products available and becoming available for the grand prix that aid in launching.
Some of these are:
Limited slip differentials
Coil spacers or spring blockers for the rear
Traction bars for the front
Lowering springs to a small degree
Struts to a small degree
Some people have even suggested some pretty radical ideas like:
Raising the rear end with a wheelie bar
Making a VHT sprayer
Running super huge slicks
Retarding timing at launch
10/26/2003 Update:
In 2003 ZZPerformance became the first FWD GP to ever get into the 1.5 60's. Our 97 M90 GTP currently holds the FWD 60' record with a 1.54 60 foot time! This was achieved by eliminating nearly all of the rear suspension travel via custom made traction system.
What I would like to discuss though is how to achieve great times with a typical stock setup. Most people don’t have all the above things so they are whom I’m addressing with this information. Here it is:
MAKE SURE that you have the proper amount of air in your tires for drag racing. You wouldn’t autocross with a nearly flat tire so why try and drag race with full pressure? Some people will rationalize this saying that they want to know how their car performs with no track preps. BAD IDEA and here’s why: On the street the pavement is rough and there are lots of small bumps for the treads in your tires to catch to gain you traction so even while spinning you get a lot of friction to move forward. On the track there is no rough surface, instead you have a ‘sticky’ surface that grips the tires very well but only until you break lose. Once you start spinning on the track you lose any sort or traction and the surface becomes very slick. Check out the drag racing tips for proper tire inflation pressures.
Do a burnout. This is extremely important. If you have slicks or drag radials you need to heat the crap out of them. This is the only way to get them nice and sticky. I’m talking about 20 seconds or more here folks. Smoke should pour off of each tire before they’re ready. If you have street tires it’s a different game. Here you want a clean fresh rubber surface but not much heat in the tire. Drive around the water box, do about 3 very short burnouts in the section between the water box and the staging, just enough to clean the tires.
Another aspect that we now need to address is rear tire pressure. Having the rear tires inflated to high pressures reduces rolling resistance. Before the days of ‘skinnies’ drag racers used to inflate their tires to 80psi or more! This is way over recommended but definitely helps reduce rolling resistance and increase mph. While these guys did this for their front tires we do it on our rears, as they are the non-driven wheels. Having the rears inflated to high pressures also reduces the tires tendency to squash under load and will help keep some weight on the front during launching.
There is one problem with inflating rears though and that is the fact that when you do a burnout you need to set the parking brake to keep from moving forward. This means that the rear tires need to hold the car in one spot and with the reduced contact patch of a highly inflated tire this can be a problem. To deal with this I usually arrive to the track with my rears set to 45 (rated max) and lower them a little if I can’t stand still in the water box. Keep in mind that with street tires this isn’t so much of an issue so keep the pressure high!
At the starting line make sure you stage very shallow. You have a few inches of play with the lights and you want to just barely trip the second light. The reason for this is that you get a running start so to speak in your launch and since you are going to be gentle with the throttle you need every inch you can get.
After you stage and both lights turn yellow you are going to do a brake stand while waiting for the lights to come down. Lightly load the transmission and hold the engine rpm around 1800. On the LAST YELLOW you go. If you wait to see the green light you are way too late. This is one of the most common mistakes that our members make and it results in terrible reaction times. The reaction time does not affect your ET but it’s still a good idea to practice for bracket racing.
Ease the pedal down taking about 1 full second to reach WOT. This is the part that you will need to get a lot of practice with. You will need to get a feel for how fast to sink the pedal. Start on the conservative side and get more and more aggressive until you start to spin the tires on launches. When you break the tires lose ease up on the gas and then get back into in when the car hooks up again. Seems like a lot to do but eventually by following these steps you will get very good at ‘feeling’ the car.
I also noticed that most people on the boards seem to make the same mistakes. Believe me the information here works, so use it! Using the information above I have laid down
