rim ?'s
Old Apr 9, 2011 | 01:18 PM
94ss06gxp's Avatar
Default rim ?'s
looking at the srt-8 charger rims, 20mm offset, not sure about backspace but would they fit? 20"x9"
Old Apr 9, 2011 | 02:45 PM
Battle_Ravage's Avatar
Wow, I didn't know they were 5x115 also, I may look into their 17s. Will the guy let you test fit them?
Old Apr 9, 2011 | 04:23 PM
RA4926's Avatar
Might be a bit wide, see if he'll let you test fit them first.
Old Apr 9, 2011 | 04:55 PM
94ss06gxp's Avatar
http://www.oewheelsllc.com/Wheels-fo...-p9360911.html
Old Apr 9, 2011 | 05:07 PM
Oh, I thought you meant real SRT-8 Alcoas... 20x9s may be a little too big. But I guess you could run big spacers and roll the fender and/or flare them so the wheels don't look like they stick out so far.
Old Apr 9, 2011 | 05:33 PM
94ss06gxp's Avatar
yeah, hmm i like the design of them and the price. guess ill have to find someone with an srt8 and see if they will let me test fit one
Old Apr 9, 2011 | 07:50 PM
Can't find any close to that in an 18x8? Someone's bond to have something similar enough.
Old Apr 10, 2011 | 03:45 AM
The Guz's Avatar
The bolt pattern is fine but the offset is what kills you. It is too low. The wheels would stick put past the fenders. As a rule of thumb, if a rim is 9 inches wide, dont go below 35 in offset. If its 8 in wide, dont go below 30. If its 7 in wide, dont go below 25. You will have issues if you plan to lower the car with that offset. Here is a pic on a 97-03 body.
Old Apr 10, 2011 | 08:01 AM
94ss06gxp's Avatar
thanks for the info and the pics man!!!
Old Apr 10, 2011 | 08:19 PM
2005gxp's Avatar
i have 18x9 with 35offset. they stick out in the back with a wide tire. 20mm offset would definately stick out.
