ideal transmission fluid temp
Instead of cutting up the factory line I found some barb fittings from derale (PN D13035) that fit into the radiator and transmission just like the factory line. That return line is a PITA to get to and splice on the MCSS so Ijust removed it all together. I never liked mounting coolers directly to the condenser so I used some 4" corner braces to put it behind the bumper.
![](http://i214.photobucket.com/albums/cc181/justin82285/07032011004.jpg)
![](http://i214.photobucket.com/albums/cc181/justin82285/07032011001.jpg)
I'm not sure of the temps, I've got no way of reading it. The fan kicks on at 180, off at 170. I wired it to run even with the key off( to lazy to find a "key on" wire) and it only continues to run during the 100*+ days. So I'd guess between 180-190*
I know this thread dates back a month but i just got the torque app with the OBDLink bluetooth interface and i cant get the tranny fuild temps to work.. It shows on my gauge selection Tranny Fuild Temp Method 1 and 2 but it only reads 32 degrees F. What am I doing wrong shocker?
2006, app, fluid, grand, ideal, oil, prix, temp, temperature, temps, torque, tranmission, trans, transmission, transmistion
