Help!!!!
Old Aug 7, 2011 | 09:46 PM
06GrandPrixGXP's Avatar
Default Help!!!!
ok so my transmission is slipping between 1st and second.. is there any fix to this and if so who do i need to contact? plz and thank you
it got bad after I installed the diablo sport predator the car has 79K on it any help is better than what i have now
Old Aug 7, 2011 | 10:45 PM
LS1 Racing's Avatar
Sorry, my friend. Rebuild time.
Contact Dave @ www.tripleedgeperformance.com.
He will set you up with a transmission that will LAST, and for less than the cost of a factory rebuilt unit.
Old Aug 7, 2011 | 10:50 PM
monte_with_a_LS4's Avatar
i would reccomend this, or if you arent doing any heavy modding and you have the 100 powertrain warranty i would go that route then put a trans cooler and shift kit in.
Old Aug 7, 2011 | 10:55 PM
LS1 Racing's Avatar
Well, if you are under warranty, get the SERTA trans from GM and call Dave @ TEP to get his his updated valve body and seal kit.
Do this whether you're modding or not, since bolt-ons are not the root cause of our trans failures.
Old Aug 7, 2011 | 11:33 PM
DavidGXP's Avatar
Stupid question.. But have you checked your transmissons fluid level? If its full, what color is the fluid?
Old Aug 8, 2011 | 04:29 PM
Brangeta's Avatar
Make sure to check your transmission fluid according to the instructions in the owner's manual and make sure it's at operating temperature which is about 190 to 200 degrees.
Old Aug 8, 2011 | 04:56 PM
LS1 Racing's Avatar
I guess I jumped the gun...With all of the reported problems, I just kind of assumed that slip=death.
My bad...Always important to check the basics first!
Old Aug 9, 2011 | 09:01 AM
Okay i will do when i get out of this freakin field cycle
Old Aug 10, 2011 | 08:29 PM
okay i check the fluid and it was at max but looked dark as heck... almost black... is that the reason for the slippage?
checked*
Old Aug 10, 2011 | 08:41 PM
Hawkins04's Avatar
if its that dark I would be changing right now
Old Aug 10, 2011 | 09:50 PM
well i would if it wasnt too late
do you think thats the cause of the 1st to 2nd gear slip?
Old Aug 10, 2011 | 09:57 PM
http://www.autozone.com/autozone/acc...Fluid/_/N-25aa
what transmission fluid is recommend for our trannys?
Old Aug 11, 2011 | 06:16 AM
ATLterrell's Avatar
Dextron VI
Old Aug 11, 2011 | 07:32 AM
Originally Posted by ATLterrell
Dextron VI
where do i get that? an the dealer said if it is already slipping that changing my trans fluid would only expedite the problem??
Old Aug 11, 2011 | 08:58 AM
Mgpeagle's Avatar
If all the fluid levels are correct then try adding some Lucas trans. fix. This will temporarily fix the problem until you can get it rebuilt.
-Mike
Old Aug 11, 2011 | 04:17 PM
-Mike
how long of a fix and how many times can it be used?
Old Aug 12, 2011 | 12:44 PM
Brangeta's Avatar
If it's black it's probably too late
Old Aug 12, 2011 | 01:08 PM
Its Lookin Like ima have to get a rebuild
Old Aug 12, 2011 | 01:09 PM
Brangeta's Avatar
By the way, I just looked it up for you in the owner's manual. It says to change the transmission AKA "automatic transaxle" fluid and filter every 50,000 miles if you drive it aggressively (which probably means almost every single GXP owner) or 100,000 miles if normally. Glad I looked it up. I'm at 40k. Says DEXRON VI as well, takes 7.4 quarts (7.0 liters) of fluid. Seems like a lot of fluid! Our cars only need 6 quarts of oil (5.7 liters).
I checked the '02 Camaro SS's owners manual and it says to change the fluid every 15k miles (!!!!) if it's an automatic and driven aggressively. If not aggressively, then every 50k. It goes on to say that the fluid never needs to be changed in a Camaro with manual transmission. Weird. Had our's changed at like 17k miles last year. Says the automatic transmission takes a massive 10.8 quarts (10.2 liters) and the manual transmission takes 4 quarts (3.8 liters).
I learned something new today.
